how to shut off GPZ750 battery light on dash ?
  • mtkawboy
  • mtkawboy's Avatar Topic Author
09 May 2012 22:38
#521114
I have a non factory battery so the little deal that goes into the battery fill plug cant be used. Is there any way to keep the battery light on the dash from blinking all the time ? The bike is an 82 GPZ750
  • Kawickrice
  • Kawickrice's Avatar
Re: how to shut off GPZ750 battery light on dash ?
09 May 2012 23:14
#521125
How easy is it to just remove the lamp from the socket?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • tito
  • tito's Avatar
10 May 2012 00:11 - 10 May 2012 00:28
#521142
If it is same as gpz1100, you just need to connect pink wire to + battery terminal.
kawickrice,
The dashboard display is LCD and red blinking warning light is used for other warning sign so it can't simply be removed.
Last edit: 10 May 2012 00:28 by tito. Reason: Add lines
  • mtkawboy
10 May 2012 22:34
#521367
Thanks, Ill give that a try with an inline low amp fuse in it & see what it does. Hope it doesnt fry anything because stock its only seeing 2.2 or so volts in one cell of the battery. Any thoughts about that ?
  • tito
  • tito's Avatar
10 May 2012 23:49
#521396
It was already connected this way when I got my bike 4 years ago. I added 10A fuse in between just in case and so far no probrem. Manual described that 6 or more voltage disable the warning sign. I looked around this forum and other old Kawasaki site and found that many of us do this method. Other mentioned that he connects 9v battery but you need to disconnect or add switch otherwise the 9v battery runs out.
  • steell
  • steell's Avatar
11 May 2012 00:59
#521428
I think on the 750 Turbo you need to add a resister between the battery + and the sensor wire.
You could check on 750turbo.com as I think that's where I read it.
  • mtkawboy
11 May 2012 19:51
#521628
The guy added the resistors to make the battery indicator lite work with a gell battery but it said you can hook it direct if you just want the lite to quit blinking. Im going to hook mine direct with the smallest inline fuse I can find, thanks for the help
