KZ1100 fuse layout
- fergieuk
KZ1100 fuse layout
09 May 2012 10:48
Hi there
could anyone tell me the fuse layout and values for my KZ. I have a pdf of the manual but cant read it.
Cheers
Fergie
Cheers
Fergie
KZ1100D1
Re: KZ1100 fuse layout
09 May 2012 11:03
Wiring diagram in FILEBASE may be helpful.
Attachment filebasekzr.jpg not found
09 May 2012 11:06
Here's a link to a free down-loadable service manual:
Click here > www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
- tito
09 May 2012 11:42
Case of my kz1100b2, the main fuse is 30A and othes are 10A. Main fuse is located 2nd from right. I assume that the layout is depend on the model.
The following user(s) said Thank You: fergieuk
- fergieuk
09 May 2012 12:09Patton wrote: Here's a link to a free down-loadable service manual:
Cheers for links Patton.
I have that manual download but fuse layout wasnt making sense and I couldnt read the pdf very well. Anyway had lifted the fuse box and noted it same layout as tito's B2 on my D1 spectre.
Does the fuse box on these give problems? I did a bladed conversion on my Yam XS1100, just wondering if worth the bother on this or just clean it up?
KZ1100D1
- tito
09 May 2012 13:05 - 09 May 2012 13:10
Yes, it is worth replacing with blade type. Blade type is easier to find from any car shop and my main fuse was kept burning out until I clean all terminal/connection with Deoxit, that was suggested by MFolks from this forum. :laugh:
btw,,, the enlarged wire diagram pdf can be found from this link.
kzrider.com/filebase/cat_view/102-1982/195-kawasaki-kz-1100-d1
this doesn't tell you the layout thought,,,,
Last edit: 09 May 2012 13:10 by tito. Reason: add a sentence
- chrisM
19 Feb 2018 22:10
I know this is a few years late but I had the same question for my kz1100 and stumbled upon this thread, so maybe this will be useful to someone down the road:
From left to right if you are facing the handlebars: Head light (10A) - Horn / Ignition (10A). - Tail / Meter (10A) - Main (30A) - Flasher (10A)
I found this pic on an eBay post of someone selling one
The following user(s) said Thank You: CCrosswait
