750 twinn spark
- aeguy1699
750 twinn spark
08 May 2012 09:06
I was wondering if any body out there has seen a 1980 kz750 that only sparks one time when you turn the kill switch from the on to off position? Durring normal cranking I have no spark. it has a new coil, plugs point and condensor, I have redone all the wireing so i know the conections are good. And swapped out the kill switch. Is there a way to test to ignightor box? The bike ran fine then i went out to start is and have no spark. Any help is very helpful Thank you guys for the great site
- loudhvx
Re: 750 twinn spark
08 May 2012 12:00
This indicates the points or ignitor box is conducting to ground all the time.
However, on a stock bike, you won't have points AND an ignitor box. You will only have one or the other.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- steell
Re: 750 twinn spark
08 May 2012 13:30
The wire between the points and the coil is shorted to ground, ether between the points and the coil or at the points. Perhaps you didn't get the points screw tight and they moved to the point where they're closed all the time.
- aeguy1699
Re: 750 twinn spark
08 May 2012 14:56
awsome thanks guys I was about to kick the bike to the curb. You were right the blue wire running to from the coil to the point was lose at the point i tightend it up and got my spark back thanks so much
