Do my homework? Looking for ideas
- gsnfl
07 May 2012 20:19
I guess this could go under chasis...bodywork..all those
Going with clip ons and a minimalist kinda look. I'd like to eliminate the entire ignition and go with switches. I read somewhere that you should use aircraft switches to handle the vibration. Thoughts? I live in a no crime area and I'm thinking about a stainless type mounted box with everything thats normally on the grips or ignition activated by toggles. Have anyone done this? Any pitfalls to avoid? Thoughts on switches? Anyone have design ideas for the box and good mounting locations? I hate trial and error building and love to steal ideas!
Thanks in advance!
Thanks in advance!
77 KZ650 C1 basket case project-blowed up and parted out
83 KZ550 M1-Prince to Toecutter transition
- MFolks
Re: Do my homework? Looking for ideas
07 May 2012 23:32
Some Mil-Spec toggle switches:
MS24523-22 SPST Toggle Switch
www.alliedelec.com/search/productdetail.aspx?SKU=6422180
MS24523-23 SPDT Toggle Switch
www.bpbsurplus.com/lc/cart.php?target=pr...7468&category_id=325
MS24523-28 SPST Toggle Switch Momentary actuation(like for a starter circuit)
www.bpbsurplus.com/lc/cart.php?target=pr...8139&category_id=325
MS24524-22 DPST Toggle Switch
www.prowireusa.com/prodinfo.asp?number=MS24524-22
SPST = Single pole,single throw
DPST = Double pole,single throw
All of the above toggle switches have screw terminals using #6 hole crimp on terminals.
Wire Termination Insulation & Sizes
Terminal Insulation Color Wire Sizes
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
The ring terminal holes comes in many sizes, from #4 up to 1/2" in most cases, it's a matter of finding the tightest fitting hole to fit the fastener for the termination.
American Wire Gauge(AWG) is backwards to what many people think; that is 22 gauge is many times smaller than 10 gauge even though the number is bigger.
RED
22-18 gauge wire
BLUE
16-14 gauge wire
YELLOW
12-10 gauge wire
- MFolks
07 May 2012 23:36
And, good ideas here:
www.gadgetjq.com/accessory_switches.htm
- MFolks
07 May 2012 23:37
www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
- MFolks
07 May 2012 23:43
I use to build missile test cables and equipment when I worked for General Dynamics/Convair Division 1983-1993, so wiring,switches, terminals, & soldering is no big thing to me.
- gsnfl
08 May 2012 01:51
Nice looking switches. Thanks!
