Charging issue affirmation needed
- ddeaton66
04 May 2012 19:21
I have checked the charging system per the manual and have found that the stator resistances are good, and the ac voltages are within limits at idle and @ speed. The rectifier voltages are normal on the main and about 1 volt low on the voltage input for regulator control. Symptom is this: at start charging is low (12.5-12.75) volts. As the bike warms up the charging increases on upwards. The warmer it gets the higher the charge rate until it reaches about 14v and it stops charging completely. After you let it completely cool this cycle will start over again. I'm thinking rectifier...but would like to know if there is a way to confirm it better.
TIA
Deat
TIA
Deat
1980 KZ550 LTD
- MFolks
Re: Charging issue affirmation needed
04 May 2012 21:24
Go to this website & download the troubleshooting guide:
www.electrosport.com/technical-resources.../fault-finding-guide
- MFolks
04 May 2012 21:30
sells,and maybe makes their own rectifier/regulators.
Two more websites to look at:
www.regulatorrectifier.com
and www.oregonmotorcycleparts.com
- ddeaton66
05 May 2012 11:27
Great info, thank you sir!
1980 KZ550 LTD
