Front brake light
- STRATOCASTER
Front brake light
03 May 2012 10:59
The brake light won't come on when I use front brake. Rear comes on fine ?
Re: Front brake light
03 May 2012 11:15 - 03 May 2012 11:15
Check the connectors on the pressure switch to make sure they're tight. The switch on my KZ650 is down at the splitter at the bottom of the triple tree (see pic).
Attachment 00000_2012-05-03.jpg not found
Last edit: 03 May 2012 11:15 by 650ed.
The following user(s) said Thank You: STRATOCASTER
- MFolks
03 May 2012 14:37
If the connections are good(check for corrosion, as it's usually non conductive), remove the electrical connections, and using a multimeter or a self powered test light, squeeze the brake lever(or if you're by yourself, put a ty wrap on the squeezed lever) checking for electrical continuity. If no continuity, the pressure switch may be bad & needs replacement.
03 May 2012 14:47 - 03 May 2012 14:47
Could also remove both wires from the pressure switch, and connect them directly to each other (by-passing the pressure switch), and see whether the brake light comes on.
Might need the ignition switch in ON position for the brake light to come on.
Last edit: 03 May 2012 14:47 by Patton.
- STRATOCASTER
07 May 2012 22:25
I took the wires of the front brake switch and made a jumper wire and hooked the two together. And BINGO the brake light came on. Tried it 5 times, each time it worked.
Thanks my friend, you are the man. I will order a new one tomorrow.
