Starter Solenoid just clicking !
- 750steve
Re: Starter Solenoid just clicking !
29 Apr 2012 17:01 - 29 Apr 2012 17:12
Ok, if anyone is wondering how to make a shunt this is what Google came up with
www.rcgroups.com/forums/showthread.php?t=393591
^^^^^^^^^ Or is that not big enough to handle the current?, would a 100A shunt be more suitable?
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 29 Apr 2012 17:12 by 750steve.
- gd4now
- Denco where did you go?
29 Apr 2012 17:11
Steve, the link I posted does explain how to make one with 2 alligator clips and a length of wire. Just look at the bottom of the link.
I quote from his post
"the best part is that the shunt is ridiculously easy to make yourself. Simply solder a Mueller #27 alligator clip to each end of a piece of #8 stranded copper wire. But be very careful about the following three specifics. First, the wire must be #8 stranded copper, available at any home improvement center, and the Mueller #27 alligator clips must be carefully soldered so that the solder does not wick up the wire. This is critical, as it affects the tool’s resistance and therefore its accuracy. Finally, the shunt’s length from clip to clip (not end to end) must be exactly 6 5/8". This is important, as an error of only a quarter inch will throw off the tool’s readability."
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- 750steve
29 Apr 2012 17:18 - 30 Apr 2012 22:22
Sorry Bruce, i got so into the explaination in that article i kinda didn't see that!
I don't have the #8 AWG wire here that he uses but i have the solid copper wire used in the article i posted but i think thats not going to have enough current rating, its 9.17pm here so i'll see if i can pick some up tomorrow.
I have some 16mm Stuff here as thats what i used for my starter motor & battery cable (no messing there eh??? :laugh: ), that equates to #5 AWG, the shunt would be way too short & i couldn't find any clips big enough for it im sure
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 30 Apr 2012 22:22 by 750steve.
- 750steve
30 Apr 2012 16:36
Ok, here are today's findings;
I drained the oil & pulled the side cover off to check the small starter cog was still in place, pressed the starter button & nothing happened, immediately i thought it was the wiring. The bikes battery (when removed) turned both starters over at the same rate when connected directly, i took them out to my car & its battery turned both of them as the same rate as the bike battery.
I refitted 1 starter to the bike & checked it again, it spun. I refitted the cog & chain, pulled the plug leads off the bike & hit the starter (bear in mind im charging the battery in between all this, i didn't use it below 12.5V) & this time the engine turned over but VERY slowly, nowhere near the rate it needed turned at to start. I pulled the starter & fitted the spare starter, it done the same thing. A couple of dabs on the starter & the battery was at 10ish Volts.
Bad points
1/ I'm suspecting its the battery, i seriously hope its just a faulty one as theres no way i can fit a much bigger battery in, i can go kick start only but i was hoping that could be just used for back up.
2/ I have no idea why the solenoid was just clicking at 1 point, the engine may have been at TDC everytime but i doubt that as it was started with the kick start about 5 times in 2 days..............i therefore don't know what the problen was that caused the origination of this thread.
Good Points
1/ Well at least i know the wiring is sound!
I'm getting the battery tested tomorrow so i'll see hw that goes. When i connect the meter to the battery terminals i get
Ignition off - 13V
Ignition on - 12.5V
Starter button pushed - 4.5V
Obviously theres something wrong there
Bad points
Good Points
Ignition off - 13V
Ignition on - 12.5V
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- MFolks
30 Apr 2012 17:06
Possibly a badly assembled battery. Is it Chinese made? I understand they have a ways to go regarding quality and expected standards for their products.
Here in the U.S., there's been dog death's attributed to rawhide treats made in China, I believe it's a brand called "Waggen Trails".
- 750steve
30 Apr 2012 19:27 - 30 Apr 2012 19:28
I have no idea where they are assembled, it says on the Shorai website that their cells are Japanese so they are mane in some area in the far east, I suspect China as the word 'Japan' is chucked into their sales pitch!
I'm getting it tested tomorrow.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 30 Apr 2012 19:28 by 750steve.
- rstnick
30 Apr 2012 21:59 - 02 May 2012 21:20
Ok, gotta read through this post some more, but had to jump in with this.
Bruce (gd4now) and Mike (MFolks) have been helping you through this Steve, and you have been calling him Rob several times.
I can see how this was happening, and is just a mistake, but when I read this I've just got to set it sraight.
Back to the top to read some more....
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 02 May 2012 21:20 by rstnick.
- 750steve
30 Apr 2012 22:05 - 30 Apr 2012 22:23rstnick wrote: Ok, gotta read through this post some more, but had to jump in with this.
Bruce (gd4now) and others have been helping you through this Steve, and you have been calling him Rob several times.
Aw bollocks........i always get you 2 mixed up!! :blink: *edit* see....all sorted now!
sincere apologies Bruce, my head is cooking a bit over this & a few other things now that the bike is running.........i have a mental idle speed to deal with (2400RPM!!! but i think i know the cause) & a rich left cylinder which was rich before the carbs were rebiult, rejetted, cleaned & float levels checked........man this is some learning experience.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 30 Apr 2012 22:23 by 750steve.
- gd4now
01 May 2012 02:05
No problem Steve, I thought about correcting you on my name, but figured that if I gave you bad info it would be attribution to Rob - just kidding.
I just thought it was more important to try to help you than to worry about what name you were calling me.
You say the bike is running now - have you solved the starter issue?
1977 KZ650 B1
- 750steve
01 May 2012 03:56
:laugh:
The bike is running, yes, but ONLY with the kick start. I should have the battery test results soon
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- 750steve
01 May 2012 07:46
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- gd4now
01 May 2012 12:24
OK - it looks like you have found the problem - the battery is toast.
1977 KZ650 B1
