2 yellow and black ground wires?
  • rickj
  • rickj's Avatar Topic Author
03 Jun 2006 14:55
#51857
I just removed the battery basket to paint it and in running wires found that one of the ground wires doesnt go to anything. The big one bolts to the block and the yellow and black plugs into something and another yellow and black just sits there- is that for some accessory I don't have or should something be in it? Bike runs fine 83LTD 750twin... and just to tell SOMEONE (wifey doesn't give a ---t (hoot). This is sorta first fix-up to keep it up (other than belt adjust, cable adjust, air filter, oil filter and change and cam chain adjust- ) This was like- clean rust, paint, make some wires nice- felt good!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 2 yellow and black ground wires?
03 Jun 2006 16:35
#51871
It can be an extra plug, not used on your model. I have a few as well. Just check over everything you removed to see if you missed something. If you have a wiring diagram for your year/model, it should show up on there.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
