Wiring up some accessories - Help Needed
  • sft1662
  • sft1662's Avatar Topic Author
27 Apr 2012 12:16 - 27 Apr 2012 12:19
#518391
I'm thinking about rigging up a couple of additional electronic items on my bike. I might try to find some low wattage (LED?) lights that I can mount on the front for greater visibility (me being seen). I also want to add a 12v charger to charge a phone on really long days.
I'm not good with electronics on the KZ but do have a manual with wiring diagrams.
How do I go about wiring up these items so that they are on when the ignition is on but wont drain the battery when the bike is off. Or even powered when the ignition is on but not "ON" unless I flip a toggle switch.
Would I have to splice an ignition wire into a relay? Something like this?
[Ground]
[Battery]----[Relay]----[fuse]+[toggle]----[lights]or[charger]
[Ignition Wire? Which one? From where? How do you properly splice...?]
I appreciate any help, I'm just trying to wrap my head around this and I know that some of you guys are really good with this stuff.
I think that there is a spare lead (brown wire in the headlight)that I can use for power for one of these, and grounding is easy enough... but any help is appreciated.
I'll also let you guys know that I have the wiring/fuse box upgrades from www.cwswiring.com/Shop.html
which provides a spare fused lead from the battery, but I'm still not 100% sure how to go about this.
1978 KZ650 B2A
Last edit: 27 Apr 2012 12:19 by sft1662.
  • MFolks
  • MFolks's Avatar
Re: Wiring up some accessories - Help Needed
27 Apr 2012 14:18
#518400
Here's information about relays and how to check them:
www.2carpros.com/how_to/how_do_i_check_a_relay.htm
www.summitracing.com/parts/PCO-5591PT/
www.mcmelectronics.com/product/26-1942
Driving lights:
Driving Light Mounts & Wiring
www.gadgetjq.com/wiredrivinglights.htm
www.shadowstuff.com/links/products_light_mount.htm
www.valueaccessories.net/Light%20Bar%20Wiring.htm
LED Driving Lights
www.webbikeworld.com/lights/motorcycle-driving-lights/
www.whitehorsegear.com/bikevis-bullets
www.whitehorsegear.com/cree-high-intesity-led-running-lights
www.jpcycles.com/product/3100441
A relay should be thought of as a remote controlled switch, it's working contacts are designed to handle 30-40 amps that would burn out normal switches. The relay will have an energizing coil, that pulls in or moves the working contacts, doing the actual work, turning on the horn, or lights.
  • MFolks
  • MFolks's Avatar
27 Apr 2012 14:25
#518403
For splicing, I use either type of heatshrinkable splice; the kind that's got built in solder, or the kind that has to be crimped, and then shrunk down.
Here's some youtube video's about splicing,proper tools to use, plus, relays, and how to wire them:
(Aircraft Electrical Tools)
(Solder Heatshrink Terminal Installation)
(Ultimate Performance Heatshrink Terminal)
(Solder Splice)
(Basic Overview Of Aircraft Electrical Terminals)
(Basics Of Automotive Wire & Battery Cable)
(How to properly Use A Crimping Tool)
(How to Splice And Repair Wires)
(Butt Connectors VS Bullet Connectors)
(How To Solder & Heatshrink Wires Together)
(Relays- An Introduction)
(Relays-How They Work
(Relays-How To Wire
