Dual magnet rotors
- Powerstroke_fan
Dual magnet rotors
26 Apr 2012 22:15
What exactly does these do? Are they worth buying? Same way with billet advancers. I would like to know more about them. Thanks
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- steell
Re: Dual magnet rotors
26 Apr 2012 23:16
Pardon my ignorance, but I have no idea what you are talking about.
Could you go into a bit more detail? Maybe even with links?
- Powerstroke_fan
27 Apr 2012 08:15
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- steell
27 Apr 2012 14:18
Looks like the blue one is only for Dyna 4000 ignitions, and they make a black one for the 2000 and Dyna S ignitions.
Dyna
Dynatek Billet Rotor allow simple replacement of the mechanical advancer assembly and ignition rotor with an attactive one piece anodized rotor. The Dyna Billet Rotor is laser etched with accurate timing marks to make ignition setup a breeze. The Dyna Billet Rotor comes in a blue anodized version with two magnents installed for use with the Dyna 4000 ignition as well as in a black anodized version with one magnent installed for use with other ignitions such as the Dyna 2000 and Dyna S ignitions.
Dyna
- Powerstroke_fan
27 Apr 2012 18:52
So do they make a noticable diffrence. i have a dyna s on my 80 1000. I have looked at them before but didnt know what they were or if they are worth upgrading to.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
