electronic tach help
- mark1122
- Keep twisting it
25 Apr 2012 18:04 - 25 Apr 2012 18:05
i bought some ZRX gauges for my KZ. they were cheap since they had no needles. Also,they have fiberglass patchwork so they must have been in a crash, but they were supposed to be in working order. Not so sure about that now.
so i got some needles, made up some brackets, mounted, and wired them up. then i started the bike and the tach needle doesn’t move.
i have a Dyna 2000 and it has 2 tach leads.. i tried both and neither worked.
my question is, is there another wiring method i should try before i give up on them? i have ordered another set, anyways, but then thought , i should ask the pros.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Apr 2012 18:05 by mark1122.
- mark1122
- Keep twisting it
Re: electronic tach help
26 Apr 2012 19:16
i just heard that i may need a resistor installed?? does this make any sence ??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
26 Apr 2012 23:21 - 26 Apr 2012 23:21
I'm pretty sure the resister is to bypass the anti-theft in the ignition switch on a ZRX.
Checked the ZRX wiring diagram to see how the tach is wired?
I'm putting a 05 ZX10 dash on a KZ750 twin, and a 01 ZX12 dash on the 96 ZX11, so I kind of have an idea of what you're dealing with.
Last edit: 26 Apr 2012 23:21 by steell.
- mark1122
- Keep twisting it
27 Apr 2012 15:48
yes i did check the wiring befor i started. the tach lead goes back to the IC Igniter.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
28 Apr 2012 00:25
I think the tach is expecting a square wave pulse from the ignitor, if the Dyna is outputting a square wave pulse and the tach is not working, then the tach must be bad.
Makes sense to me anyway.
Where you at Lou?
Where you at Lou?
- loudhvx
28 Apr 2012 15:13
Here, but I don't really have much to add to what you said. I don't have much experience with factory tachs. My gut feeling is to suspect the Zrx tach is bad as well. As you said, it's generally going to expect a square pulse.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- mark1122
- Keep twisting it
28 Apr 2012 15:35
well u guys r way ahead of me. i dont even know what a square pulse is. last i heard , i was trying to put a square peg in a round hole. :woohoo:
whats a square pules?
I have ordered another tach, and gotten a reply from Dyan tech. They said to try running the tack from my coils negative lead.
I have put my old gauges back on for now. I have 3 track bikes to prep, so not much time for the kz. When the new gauges show up, I’ll try the coil lead and retry the dyna leads. Then I will either be happy or sad.
Thanks for the replys back at ya soon.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- loudhvx
28 Apr 2012 18:01
The signal that the tach uses is a DC signal which changes from roughly 0 to 12v everytime a coil fires. It's the standard pulse that most tachs use from that era.
The way to get that signal, on most tachs from that era, is to connect the tach wire to the negative wire on the coil. That is the wire that goes from the coil to the igniter. On a normal KZ, that wire is black for the 1-4 coil, or green for the 2-3 coil.
1981 KZ550 D1 gpz.
Other links.
Other links.
- MFolks
28 Apr 2012 18:17
The see a square wave,an Oscilloscope is needed. It displays the waveform on a CRT(Cathode Ray Tube) much like a TV screen. It can also be used for troubleshooting, probing components for proper operation.
- mark1122
- Keep twisting it
29 Apr 2012 10:59
Well that makes it perfectly clear. :blink: i am now qualified to be an electonics scientist. :S
i think i had better stick to beer analysis :woohoo: .
Thanks
Thanks
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
29 Apr 2012 11:35 - 29 Apr 2012 11:39
Mark, if you truly want to test this out...
A simple 555 timer design (~ 16.6 pulse per second = 1Krpm) should be able test this out for you...
With potentiometer , leave user adjustment for 1K -> 10Krpm...
Basically you're building a Frequency pulse generator versus square wave (50/50 duty cycle)...
You'll need a 12Vdc power supply as well, wall transformer will be sufficient.
Do you have the wiring diagram for this unit...?
If interested to try, e-mail me the wiring diagram you have and I'll draw you up a simple circuit for parts readily available at Radio Shack...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 29 Apr 2012 11:39 by Old Man Rock.
- mark1122
- Keep twisting it
30 Apr 2012 11:18
Thanks Dave. That would be great.
i may take u upon this, but let me try the simple route first.when the new gauges come in i'll give it another go. if they fail then i'll give u a buzz.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
