Flashers flashing...flashers not flashing
- gsnfl
23 Apr 2012 19:12
77 KZ650C-1 sat over the winter and was fine when I parked it. Toward the end of the year I had this weird problem that I eventually figured out was the emergency flasher relay causing the whole bike to surge. Weird...
so I replaced the relays (Turn signal and emergency) with a triton 552LL. Im beginning to think that this isnt the correct relay for either application. Can anyone confirm this?
Flasher relay connected or turn signal connected (or both for that matter) and the flashers wont turn off. If I use the old relay, it works but that relay is faulty and it eventually blows the main and gets gaaaaadamn hot.
Bike is a recent basketcase that I'm slowly unraveling the PO's nightmare.
Yes, I did the deoxit thing.
77 KZ650 C1 basket case project-blowed up and parted out
83 KZ550 M1-Prince to Toecutter transition
- DiamondSkyBlue1000
Re: Flashers flashing...flashers not flashing
24 Apr 2012 02:38
First thing, do you have the stock setup? Original bulbs, proper size and the like? Not LED? Any deviation from the original configuration?
- MFolks
24 Apr 2012 02:56
Look at this website:
diagrams.kz650.info/
24 Apr 2012 08:44 - 24 Apr 2012 08:45
I used a Tridon/Stant 552 2 prong flasher on my KZ650-C1 for the turn signals and it works great. The hazard flasher is still stock, so I don't know if the Tridon is correct for that application. Ed
Last edit: 24 Apr 2012 08:45 by 650ed.
- BikeDude2002
- Today is a good day to ride...
01 May 2012 02:29
Might consider a modern upgraded flasher at
www.cwswiring.com
:woohoo:
78 KZ650 SR
90 Yamaha Radian
90 Yamaha Radian
- gsnfl
08 May 2012 02:11
Wow! Perfect products! Thanks
