1981 KZ1000 LTD
  • dman
  • dman's Avatar Topic Author
1981 KZ1000 LTD
17 Apr 2012 15:28
#516357
Is it possible to have the wrong coil hooked up to the wrong plugs. As far as ( sitting on the seat) having the right side coil hooked up to 2&3 versus the left? I have been having problems getting spark to any cyclinder and I am wondering if I could have burned up both coils at the same time. I have done the old block test chenged wires and plugs. I get power to the coils but absolutly nothing comes out.
  • MFolks
  • MFolks's Avatar
Re: 1981 KZ1000 LTD
17 Apr 2012 16:30
#516363
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different).
The 550’s, 650’s, 700’s & 750’s are backwards to what is listed for the bigger 4’s.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s, 650‘s,700’s, and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
An indication of black and sooty sparkplugs may not mean a carb or carbs are in need of cleaning, but may mean the input voltage is low.
When checking the input voltage to the ignition coils, first have a fully charged battery, and the using a multimeter, set it up to measure VDC(Volts, Direct Current), range of 20.
Put the RED probe from the multimeter on the same terminal that either a RED wire or ones that’s RED with YELLOW stripe, and the BLACK probe on either a good frame/Earth ground or the battery Negative(-) terminal/post.
Depending on the motorcycles current draw( lighting, and other high amp needs) the reading might be 10 volts or more, but if the reading is down around 8 volts or less, this indicates a corrosion or wiring problem needs correcting to improve input voltage to the coils.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
  • MFolks
  • MFolks's Avatar
Re: 1981 KZ1000 LTD
17 Apr 2012 16:33
#516364
Does your bike have ignition points or electronic ignition?
If electronic ignition, the (pulsing) or pick up coils may be failing due to heat.
Ohm Checking Pickup(Pulsing) Coils
The pickup(Pulsing) coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(BEHIND A RIGHT SIDE, CD SIZED COVER) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
  • dman
Re: 1981 KZ1000 LTD
19 Apr 2012 16:19
#516692
It does have kawasaki installed electric ignition. I thank you very much for all your information. I think i'm going to change out the IC Igniter at this point. I have already put on two newish coils off of a GPZ900 I blue up years ago. They check out fine. That IC Igniter has to be the problem. Too bad its mounted in a terible spot. I have to pull the battery, air box,,maybe carbs to get air box out. Live and learn right!
Re: 1981 KZ1000 LTD
19 Apr 2012 23:43 - 19 Apr 2012 23:45
#516798
dman wrote: ...IC Igniter has to be the problem. Too bad its mounted in a terible spot. I have to pull the battery, air box,,maybe carbs to get air box out....
Imo, removing the air box is ill-advised.
Usually the igniter is readily accessible and relatively easy to remove.
Folks do it all the time when converting to Dyna-S ignition.
Good Fortune! :)
Last edit: 19 Apr 2012 23:45 by Patton.
