Bike wont turn off?
- xbmxxx
Bike wont turn off?
15 Apr 2012 22:56
got my bike running for the first time this weekend. 80 kz750 twin, electronic ignition off a kz440, and a complete rewire. I started it for a few minutes on friday and then shut it off. All was fine (electrically). Today I let it idle for about 20 minutes and warm up to charge everything. When I turned the key off, the bike keeps running, the lights stay on, etc. I then unhooked and removed the battery, no change. I finally just shut off the fuel petcock and let it run out of gas.
Any ideas on what would cause this?
76 KZ750B Twin
- loudhvx
Re: Bike wont turn off?
15 Apr 2012 23:11 - 15 Apr 2012 23:13
Most likely cause is a wiring issue at the ignition switch, especially since it is an aftermarket car switch.
My experience with those universal car switches is that they are no well made. Sometimes the switching plate inside comes loose and rotates to where it can't be turned off. Or it's possible a piece of metal is loose in there preventing shutoff.
Another possibility, that happens commonly with those switches, is the wiring posts come into contact with the wires.
You should be able to pull that main fuse (Fuse 1 on the diagram) to kill the bike.
There is also a small chance that the reg/rec wiring has a problem. If the reg/rec shorts out brown-to-white, the bike would keep running where the fuse will make no difference.
An then there is the possibility that there are just some crossed wires somewhere.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 15 Apr 2012 23:13 by loudhvx.
The following user(s) said Thank You: xbmxxx
- xbmxxx
16 Apr 2012 21:35
alright, thanks.
The switch I used was this one
www.jegs.com/i/Flaming-River/898/FRIGN1/...rentProductId=752487
after having 2 of the autozone ones be bad straight out of the box. I was hoping the flaming river one would be better quality, perhaps I was wrong. Ill check later and see if pulling that fuse kills it.
hey, at least I know my charging system is working! haha.
76 KZ750B Twin
16 Apr 2012 22:49 - 16 Apr 2012 22:53
If interested:
www.z1enterprises.com/Ignition-Switch-wi...0-KZ1000-Z1-369.aspx
www.z1enterprises.com/detail.aspx?ID=4518
Last edit: 16 Apr 2012 22:53 by Patton.
- xbmxxx
17 Apr 2012 22:13Patton wrote: If interested:
appreciate the links, but its going on this.
the car syle is about the only option I have. I may just have to add a kill toggle switch in to the 20a main wire.
76 KZ750B Twin
- xbmxxx
22 Apr 2012 15:18loudhvx wrote: Most likely cause is a wiring issue at the ignition switch, especially since it is an aftermarket car switch.
Got to messing with it some today. Pulling the main fuse doesnt shut it off either. So I guess I have a short in my reg/rec wiring?
76 KZ750B Twin
- loudhvx
22 Apr 2012 15:28
Any short that re-routes power around the fuse and switch could do it. A wiring short is more likely than the reg/rec itself being shorted in that manner.
If there are no wiring shorts, and pulling the fuse makes no difference, then it would likely be the reg/rec itself. But they usually don't fail that way.
I would remove the reg/rec, then run the bike on battery for a few seconds and see if it shuts off.
If it does, then you need to check the reg/rec wiring. If the wiring is good, then I guess time for a new reg/rec.
If you have the reg/rec hooked up, you must have the brown wire to the reg/rec in tact or it may fry the bike.
1981 KZ550 D1 gpz.
Other links.
Other links.
