78 kz650c2 starting issue?
- Mine20
- Metric Maniac
15 Apr 2012 14:14
Gentlemen,
So I have been working on my build for about 6 months now. Here is some back round.
78kz650c2
dyna S coils
Shorai battery (brand new)
re-wired so all connections are good
Issue:
We all know that these are cold hearted bikes and are a pain to start cold. I do not have use of my kick since i have installed rear sets. Yesterday while attempting to start I got the usual odd noises KZ's dump out. Then all of the sudden it seemed like the starter motor stays engaged for a good 3-5 seconds AFTER I release the start button.
What I have done to remedy so far:
swapped out the starter solenoid.
swapped out the starter motor.
took apart the start switch and cleaned it out.
inspected the gears on the starter motor.
Each time I swapped something out I attempted a restart and the same thing happens. The starter motor seems to stay engaged.
The motor is attempting to turn over but needs a little help (starter fluid).
Any ideas? Any other info, pics, video you need let me know.
Thanks!
Marc
78kz650c2
dyna S coils
Issue:
Thanks!
Marc
2007 Honda Shadow Custom
1978 Kawasaki kz650c2 cafe project
1979 Kawasaki 650sr possible bobber project
- MFolks
Re: 78 kz650c2 starting issue?
15 Apr 2012 15:25
What weight and type of engine oil being used? Most riders have good results with Shell Rotella T-6 oil. I suspect the over running clutch starter mechanism is hanging up(possibly a burr or two on the part that engages the starter motor).
- TeK9iNe
- What did you do!?!
15 Apr 2012 15:35Mine20 wrote: We all know that these are cold hearted bikes and are a pain to start cold.
I somewhat dissagree with this statement... Yes they are deffinately a cold-blooded animal stemming from the air cooling technology of thier time, but all KZs I have come across and fine tuned, start instantly with but a 1-2 second click of the starter.
Bummer :S I love kickers.
? Oh... you mean the usual digesting nails kinda sounds - gotcha :lol:
Yeah not good
Its most likely as MFolks suggested, a problem with the starter clutch mechanism, and parts replacement will most likely be in order. Dissasemble and inspect
You shouldnt need to use anything extra to start your bike if its tuned up properly. Nice clean carburetors in wel tuned and synced state with a reasonably good compression motor will start easily even with a slow turning starter. I suspect a go thru of the maintenence chapter of your manual is on order - a thorough tune-up.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Mine20
- Metric Maniac
15 Apr 2012 18:12 - 15 Apr 2012 18:30
Oil being used in 10w40 Maxima racing oil.
Prior to changing it from stock it started right up without a problem. Things that were changed are:
Pods
4-1 exhaust no muffler
I rejetted but kept dumping fuel from the bowls. So I went and put the old jets back in. This is when it started again with starter fluid. Once it warmed up it started on it's own without issue.
I have done the usual maint suggestions here and on Kzinfo.com. I have not sync'd the carbs yet I am planning on I picked up an old school mercury sync tool.
I did inspect the starter clutch mechanism and it seemed fine. Prior to yesterday it was not making the odd noise after hitting the start button.
Heres a video.
Pods
Heres a video.
Last edit: 15 Apr 2012 18:30 by Mine20. Reason: added video
- Mine20
- Metric Maniac
17 Apr 2012 23:08
Thinking it's the starter clutch. . .
