starting issue, solenoid clicks, good battery
- jjack010
12 Apr 2012 19:37 - 12 Apr 2012 19:42
The last time I tinkered with the Z1 was before my deployment overseas, May of last yr. I had an oil leak from the left side engine cover. After removing the cover and fixing the leak, the bike would not fire. I stored it for about 10 months and I'm ready to get it back on the road. I replaced the battery so I can take that out of the equation. I would like to say the solenoid or starter is bad and it's just a coincedence that it happend while I had the left side engine cover off. Any thoughts? What should I check and how do I confirm? I'm trying to avoid dropping it off at a shop. I do have a good multimeter and test light. I did run a wire across the 2 terminals on the solenoid (battery/starter)and got nothing but an arch.
1974 Kawasaki Z1
Central Texas
Central Texas
Last edit: 12 Apr 2012 19:42 by jjack010.
- MFolks
Re: starting issue, solenoid clicks, good battery
12 Apr 2012 19:57
Starter Solenoid/Motor Checkout Procedure
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery, and then use a floating ball hydrometer to check specific gravity in the charged cells).
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight. If the cables feel “Crunchy” when flexed, they may have corrosion inside the insulation, requiring replacement.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike, keep in mind some Kawasaki’s have a clutch interlock to prevent cranking the engine while it’s in gear, so the clutch lever must be squeezed.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. A website for starter motors is:
A. www.psep.biz/store/mitsuba_starter_motors_page_2.htm
B. www.nationsautoelectric.com/Kawasaki.html
C. www.whitedogbikes.com/cat--Kawasaki-Star...-Starter-Motors.html
D. www.ricksmotorsportelectrics.com/starters.php
E. www.dbelectrical.com/
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit. Be aware that the new solenoid from the lawn mower shop may require a ground wire for it to work.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot, so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
- MFolks
12 Apr 2012 19:58
And:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start. The older Kawasaki’s have reports of the soldered connections crumbling, if your bike has this problem, just ask, as I’ve got a repair procedure for this.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
- jjack010
12 Apr 2012 20:47
I just finished cleaning all connections to the battery and starter solenoid. Negative battery cable looks good. Positive feels like it needs replacing so I'll pick one up tomorrow. I have 12.55VDC from the battery. I have 12.55VDC off the battery side of the starter solenoid. With the ignition on and starter button pushed, I have 4.5VDC off the starter side of the solenoid with a faint click. I'll bounce this off the shop manual but it sounds weak and the numbers sound low. I may have damaged it further when trying to beat it out of the mounting clamp once removed from the bike.
1974 Kawasaki Z1
Central Texas
Central Texas
- MFolks
12 Apr 2012 20:53
Solenoids do fail, either internally on the contacts, or the energizing coil quits working.
- jjack010
12 Apr 2012 21:01
I just did the starter relay contact test per the kawi shop manual. Ohms across the terminals was OL when it should be at 0, which tells me it's faulty. Ohms across the 2 black wires is 0, where it should be. I'll try to locate a solenoid and battery cable tomorrow and keep you all posted. Thanks for the quick responses!
1974 Kawasaki Z1
Central Texas
Central Texas
