Dyna S ignition system thoughts
- BizzareCustoms
10 Apr 2012 19:06
hey my coils took a dump on me and i was going to replace them with some dyna units and was contimplating swapping out the points for the dyna s setup but was curious if anyone is using it and what their thoughts are on it. would be nice to not have to worry about and adjust points any more. my bike is a 78' kz650 btw
- loudhvx
Re: Dyna S ignition system thoughts
10 Apr 2012 19:23
Dyna S is better than points, but inferrior to Kawasaki electronic ignition.
Also, on a 78 KZ650, there will be a good chance of having carging issues because the Dyna S wastes a lot of power as heat.
Search Dyna S and kz650 single phase.
There are many threads on single-phase KZ650 charging systems failing to kee up with the demands of the Dyna S, leaving batteries dead.
The solution, in just about every case, was to upgrade to a 3-phase charging system, or get rid of the Dyna S.
Dyna S would require 3 ohm coils or higher, while the Kawasaki system ideally requires 2.3 ohm coils (Dyna sells 2.2 ohm which are just right).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
10 Apr 2012 19:23
I have no problems with it . Using Dyna green coils . This is on a high power 1000
I would buy it again.
- BizzareCustoms
10 Apr 2012 21:34
was planning on running the Dyna-S Electronic Ignition DS2-2 along with two Dyna Dual Output 3.0 Ohm green Coils and a set of the Dyna 7mm copper core wires.
I should also mention that the only other power consumers I have on my bike is a 100w head light, a stop ligt, and led tag lights. I have removed all other lights, horns, ect. (feel free to check out my project build)
- RonKZ650
10 Apr 2012 23:50
Lou knows his phases. I'm not sure what phase charge system the 78 650 has vs the 77. I ran a Dyna 3 on a 1978 KZ650 for 160,000 miles and a DynaS on a 1977 KZ650 with a 1978 charge system for 45,000 miles and never had a hint of a charge problem. I use stock coils, yes 160,000 miles on stock coils with no problems. Also have another 77 with DynaS and Dyna green coils. Motorcycle has only 24,000 miles on it and I bought it the way it is. It has no charge problems either. I think you're safe to trash the points. I trashed mine back in 1979. Some guys love points, I'd rather be shot than ever see another set of them damn things.
- MFolks
11 Apr 2012 00:04
If you use the Dyna S system, do not use the supplied splice to power the Dyna, as it is not a good electrical connection. You're much better of soldering the joint & then cover it with heatshrink tubing.
This type of spice is called a "suitcase splice" as it resembles a closed suitcase, but if the joint gets wet, corrosion will quickly set in, making for intermittent/sporadic operation.
- loudhvx
11 Apr 2012 14:11
I realize I sounded a little more negative in my previous post than I meant to.
There are certainly many 78 and 79 KZ650's with working Dyna S ignitions that are not experiencing charging issues, even though they are 1-phase. (The 77 KZ650 has a 3-phase, excited field charging system.)
I should have said, of the bikes that experience charging system problems after installing a Dyna S, most of them are 78 and 79 KZ 650's with stock charging systems. I suspect that those years had some charging systems that had slightly less extra capacity. They worked fine for stock ignitions, but the Dyna S used up the extra capacity, exposing the limits of the charging system.
There are several solutions. Probably the best, but most expensive is to convert to an aftermarket 3-phase stator and regulator/rectifier. That's around $200. Or you can get a later 3-phase 650 or 750-4 stator and reg/rec. That may be around $100 or less, used.
And there is a good chance that it will work fine.
The 550's, 900's, 1000's that use Dyna S ignitions don't seem to suffer from this problem.
1981 KZ550 D1 gpz.
Other links.
Other links.
11 Apr 2012 15:08
- BizzareCustoms
11 Apr 2012 17:46MFolks wrote: If you use the Dyna S system, do not use the supplied splice to power the Dyna, as it is not a good electrical connection. You're much better of soldering the joint & then cover it with heatshrink tubing.
i know the type of splice pack you are talking about and agree with you. i solder and heatshrink all my connections
- BizzareCustoms
11 Apr 2012 17:56
i guess ill wait untill i have the money to do the dyna s system. worse comes to worse i take it off, sell it, and put stock rated coil packs. Maybe ill set up a temporary voltage and amperage gauge set up for a couple of rides to verify that the charging system is able to keep up. ill update when the time comes and maybe do an install thread.
- Bear2123
13 Apr 2012 15:54loudhvx wrote: I realize I sounded a little more negative in my previous post than I meant to.
Just upgraded the Grandsoon's '79 KZ650C3 with an '81 KZ750E stator, rotor and reg/rec. Works great, bought all 3 off e-Bay for under $70 shipped. Bike was purchased witht he Dyna S ignition and 3 ohm coils. Bike would never charge the battery and would stopp running in around 2 hours when the batter didn't have enough power for the headlamp, running lights, brake light and ignition. Easy change out/parts swap. Only one "extra" wire to hook into the '79 wiring system. Changeover only too a couple hours. Now the bike is reliable and the battery stays charged.
- loudhvx
14 Apr 2012 13:47
Thanks, nice job Bear!
1981 KZ550 D1 gpz.
Other links.
Other links.
