Stop lamp stays on
- Brett0424
Stop lamp stays on
06 Apr 2012 01:06
My brake light started staying on full time today. I don't believe the rear brake spring is pulling it down, what actuates the light for the front brake? Could it be stuck? Thanks.
Brett
Brett
80/81 KZ440 frankenstein
- nobody
Re: Stop lamp stays on
06 Apr 2012 01:16
dont know what you got but yes .should be a small switch up by break lever on front .but like i said dont know what you got
- Brett0424
06 Apr 2012 10:17
It's in my sig. kz440 built from 80-81 parts.
- bluej58
06 Apr 2012 22:47
Check the brake adjuster screw to see if it is screwed out to far , holding the pedal down.
That would trigger the brake light switch.
JD
JD
78 KZ1000 A2A
- DiamondSkyBlue1000
06 Apr 2012 23:50
You should have a small mechanical switch mounted right where your front brake lever is attached to the master cylinder. Try unplugging it to see if the light goes out. If it does, then it's the problem. My guess is it just needs to be adjusted. If it doesn't go out then do the same procedure for the rear brake switch located where your rear brake lever is attached to the frame.
