charging
  • busted knuckle
  • busted knuckle's Avatar Topic Author
charging
01 Apr 2012 18:17
#513421
I was 250 miles into a trip when all of a sudden the engine dies. i got it started again. then it died again. when i got to the side of the road the battery was almost dead. is it possible its the battery or charging system?
1979 kz 750 b4
  • Old Man Rock
  • Old Man Rock's Avatar
Re: charging
01 Apr 2012 19:46
#513434
engine/Regulator ground is my first/gut feeling. ;)
Manual & volt meter should provide you for verifying the culprit.... While running @ idle >13Vdc @ battery terminals...?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: 1slowkayzee
  • busted knuckle
Re: charging
03 Apr 2012 19:39
#513866
there was smoke coming from what appeared to be the wiring harness. a friend told me to cut open the harness and look for frayed wires. I didn't find any but it does look like the smoke is coming from the negative battery terminal. if that could still be engine regulator ground. how do i fix it?
1979 kz 750 b4
  • busted knuckle
Re: charging
06 Apr 2012 11:17
#514351
I had a friend come over who is a real mechanic and he tested the battery and said it was junk the replacement is charging right now. Hope to get back on road later today
1979 kz 750 b4
