Help!!! Losing two cylinders! Can't figure out why
- Kz650harvey
31 Mar 2012 14:54
I just replaced both coils on my 1980 kz650f because it wasn't firing on two cylinders (#'s 1 and 2)and I thought the coils might be bad. Now that I have replaced them I'm dropping the other two cylinders ( #'s 3 and 4). What does this mean? How can I fix it?
Re: Help!!! Losing two cylinders! Can't figure out why
31 Mar 2012 15:36
Are you sure the plug wires are connected properly? One coil fires cylinders 1 & 4, the other fires 2 & 3.
- ramtough_63
31 Mar 2012 15:58
Check your coneection get it running keep it running wiggle wires see if anything changes
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Kz650harvey
01 Apr 2012 11:03
I tried taking the wires from #'s 3 and 4 off to see if they were doing anything and it ran worse
. So they are firing a little. Could this be carburation?
- Motor Head
01 Apr 2012 11:17 - 01 Apr 2012 11:18TexasKZ wrote: Are you sure the plug wires are connected properly? One coil fires cylinders 1 & 4, the other fires 2 & 3.
+1
Get your coil wires connected properly, both primary and secondary. Black to 1&4, Green to 2&3.
Last edit: 01 Apr 2012 11:18 by Motor Head.
Last edit: 21 Feb 2013 15:35 by martin_csr.
