Left turn signals not blinking.
- MTH76
29 Mar 2012 09:03
My right turn signals blink normally but the left doesn't.
I changed flasher and checked the bulbs and they are fine.
Any help would be great!
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
- kfs
Re: Left turn signals not blinking.
29 Mar 2012 12:30
Had same problem it turned out to be a bad ground.
- MTH76
29 Mar 2012 14:17
I will check the ground.
They both light up so I didn't think of that.
- MFolks
29 Mar 2012 14:18
Look inside the turn signal housing,for the front signals, there should be three wires, one for the running lights, one for the signal, and another for the ground.
The rear signals do not have running light circuits, so there should be but two wires; one for the signal, and the other for the ground. Kawasaki grounds are usually Black with Yellow stripe.
Sometimes vibration will break the conductor inside the insulation, so check with a multimeter for continuity.
- RonKZ650
29 Mar 2012 17:16
Also check the bulb on the instrument cluster. If it doesn't light the bulbs will not blink. Flasher is load sensitive, not enough load it won't flash.
