replacing pickup coils only ?
  • Treewizard
  • Treewizard's Avatar Topic Author
27 Mar 2012 00:02
#512234
recently found that one side of my pickup coils wasnt firing and am wondering if this dyna part is ok to buy as a stand alone replacement part.
B)
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
  • MFolks
  • MFolks's Avatar
Re: replacing pickup coils only ?
27 Mar 2012 00:10
#512236
Does your bike have the Dyna ignition, or the Kawasaki ignition? Kawasaki pick up coils are available, but I don't think the parts are interchangeable due to mounting and ohm differences.
Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
  • Treewizard
30 Mar 2012 17:02
#513051
bump?
anyone else have any in put on the subject?
experience with only replacing the pickup coils?
:P
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
  • loudhvx
  • loudhvx's Avatar
30 Mar 2012 18:47
#513063
That link was to a Dyna S ignition. That ignition has everything built into the pickup plate. That is a complete replacement ignition system. It is not to be used with the factory ignition box. It also should not be used with the original coils.
The Dyna S ignition requires 3 ohm coils. The factory electronic ignition uses 2.3 ohm coils, so you would need to get new coils to go with that Dyna S.
(If your bike would have had points, then you could have used the old coils with the Dyna S.)
