No brake lights for 1982 1000ltd
  • Fw4jy0
  • Fw4jy0's Avatar Topic Author
  • 1982 KZ1000K LTD
23 Mar 2012 13:16
#511477
Change bulbs still no work. I pull in front brake lever and depress rear brake lever and no lights come on. Anyone help??
Rick Pasek
Re: No brake lights for 1982 1000ltd
23 Mar 2012 13:33
#511479
Fw4jy0 wrote: Change bulbs still no work. I pull in front brake lever and depress rear brake lever and no lights come on. Anyone help??
This wiring diagram should be very close and might be helpful:
Click here > www.kzrider.com/filebase/doc_download/265-z1000m2
Or find other wiring diagrams, etc. through the FILEBASE.
Attachment filebasekzr.jpg not found
Would assure the black/yellow wire is providing a good ground connection.
Good Fortune! :)
The following user(s) said Thank You: Fw4jy0
23 Mar 2012 13:38 - 23 Mar 2012 13:39
#511481
Assure good wiring connections at the pressure activated switch (front brake light) and at the mechanical switch that's supposedly operated by depressing the rear brake pedal.
The rear switch is adjustable to provide the correct spring tension whereby the switch connects when the pedal is depressed and remains disconnected while the pedal isn't depressed.
Good Fortune! :)
Last edit: 23 Mar 2012 13:39 by Patton.
  • MFolks
  • MFolks's Avatar
23 Mar 2012 13:42
#511482
I'd check the fuses first before getting into the wiring, as the older glass tubed fuses can fail but look good. AGX is the type of fuse needed, most auto parts stores can get them for you.
Here's the wiring color codes for the brake/tail light circuit:
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
BLACK with YELLOW stripe, the ground circuit.
23 Mar 2012 13:42
#511483
It might be necessary to turn the ignition switch ON to provide voltage for the brake light.
