80 750 twin no spark
- xbmxxx
I wired it as per the awesome diagram loudhvx made me in the bare bones thread.
Not getting any spark out of the coil. When I test the coil, I have a good 12v with the yellow/red wire. yel/blu has continuity to ground when key is in the on position, but becomes open when cranked.
Is the ignitor not working correctly? I may be completely wrong here, but I would assume that the ground continuity should be switching off on off on when cranked, and it should spark at each point of continuity?
Bad coil? or possibly something else in the ignition?
76 KZ750B Twin
- Thank you received: 2098
xbmxxx wrote: ...would assume that the ground continuity should be switching off on off on when cranked, and it should spark at each point of continuity?....
Interruption of the coil primary winding's ground connection is the event that causes a charged coil to fire though the secondary loop.
- steell
- xbmxxx
steell wrote: If it has Kawasaki electronic ignition, then the igniter should not ground the coil unless the motor is turning over, so either the wiring is messed up or the igniter is bad.
that's pretty much the exact opposite of what its doing. Looks like i'll be hitting the scrapyard for a new ignitor this weekend.
76 KZ750B Twin
- loudhvx
- Thank you received: 1616
Some aftermarket ignitions work that way... ie, ground the coil most of the time, then un-ground it periodically when the motor is cranked over.
If you can't find an igniter, you can try the HEI version in my signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- xbmxxx
It looks factory. The part number is SH347.
76 KZ750B Twin
- loudhvx
The twin igniters are just a black box, whereas the inline-four igniters have fins.
1981 KZ550 D1 gpz.
Other links.
- xbmxxx
Still no spark.
I went through the wiring test per kz400.com. All the tests were a pass except one.
it all passed except for 5. and 6.
Any idea what would cause that?
76 KZ750B Twin
- loudhvx
What voltage do you get on each of the pickup wires?
Also, if you disconnect the pickup wires at the igniter, then measure the resistance of the pickup, what do you get?
1981 KZ550 D1 gpz.
Other links.
- xbmxxx
76 KZ750B Twin
- loudhvx
1981 KZ550 D1 gpz.
Other links.
