Replacement for front brake light switch
  • osage
  • osage's Avatar Topic Author
20 Mar 2012 22:23
#510929
I just noticed that my front brake light switch does not work on the kz750H3. Closer inspection revealed that the actuating rod is missing from the switch. The part has been cancelled by Kawasaki but found a few on Ebay.
Found a single banjo bolt brake light switch on z1Enterprises. www.z1enterprises.com/Brake-Light-Switch...mm-x-125mm-3379.aspx
It looks like it would be a better choice then NOS from Ebay. Searched posts and it looks like other members have used this type of switch. I plan on replacing front lines at same time. Has anybody had problems with changing to this type of switch?
1976 KZ750B1
1982 KZ750H3
