Spark plug wires
- xbmxxx
Spark plug wires
19 Mar 2012 13:36
I'm having trouble finding a set of plug wires for my kz750g twin. Factory coil. Anyone know where to get a pair or if I can just use an auto style wire? These have a weird end that screws on to the coil
76 KZ750B Twin
- bountyhunter
Re: Spark plug wires
19 Mar 2012 16:30
The 750 twin wires are molded as part of the coil assembly. Z1 Enterprises sells an EMGO four Ohm replacement coil for $36 that sparks better than stock. Just get the whole thing, don't fool with the wires.
- xbmxxx
19 Mar 2012 19:33
I checked there first, but this is the only non Dyna coil they have listed.
www.z1enterprises.com/Ignition-Coil--Uni...l--12-Volt-4139.aspx
76 KZ750B Twin
- xbmxxx
19 Mar 2012 19:35 - 19 Mar 2012 22:23
I should also mention that someone before me swapped the points for a later models ignition system
this is what my coil looks like.
[img]http://http://www.ebay.com/itm/Kawasaki-1981-KZ750-Twin-KZ-750-Ignition-Coil-/160629816426?pt=Motorcycles_Parts_Accessories&hash=item2566487c6a&vxp=mtr[/img]
76 KZ750B Twin
Last edit: 19 Mar 2012 22:23 by xbmxxx.
