no spark 550 spectre 1982
- bic
16 Mar 2012 00:46
there is power to coil no spark the coil is good
- MFolks
Re: no spark 550 spectre 1982
16 Mar 2012 01:02
It could be a bad IC igniter(it gives the ignition coils their grounds, sparking the plugs) or bad pick up coils.
Do this test:
Ohm Checking Pickup(Pulsing) Coils
The pickup(Pulsing) coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(BEHIND A RIGHT SIDE, CD SIZED COVER) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
If the pick up coils test good, ask "Loudhvx"(a forum member here) on how to build and wire up his IC igniter replacement.
Do this test:
17 Mar 2012 01:02 - 17 Mar 2012 01:04
Would also confirm that the igniter is properly grounded via the black-yellow wire.
Last edit: 17 Mar 2012 01:04 by Patton.
