Turn Signal Question
- badrhino
15 Mar 2012 19:57
I searched and couldn't really find anything.
Is there a turn signal that can be put in place of the bolt on each side of the headlight mounting bracket? I have the old bar mounted ones and don't like the looks of them.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- MFolks
Re: Turn Signal Question
15 Mar 2012 22:23
Maybe something from this supplier:
www.kandstech.com/
I'd ask www.z1enterprises.com if they can order a signal assembly for you as I'm not sure K & S sells to the public.
www.kandstech.com/
- les holt
15 Mar 2012 22:40
I did just what your talking about. I used the short stems and turned the diamond shaped area down to 1/2" and opened up the headlight bracket up to fit then used the normal components to reassemble.
hth.
Les
hth.
Attachment turnonheadlight.jpg not found
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- badrhino
15 Mar 2012 23:50
That's a purdy front end Les. What are the forks off of? I take it you made the triple tree.
Franken Z!
Franken Z!
