Electronic Tach
- badrhino
Electronic Tach
14 Mar 2012 13:00
I am looking for an electronic tach for my KZ since it has a J motor and 1100 heads on it and there is no mechanical tach drive. Will any tachs from other bikes work or the cheap universal ones? I know the KZ uses a "wasted spark ignition" meaning that each coil wire fires twice. Is that going to make the gauge read funny?
I was think of using one off of a late 90's Katana 600 or possibly one off of a Kawasaki Vulcan. Or if need be buy a cheap aftermarket one.
Any suggestions?
Any suggestions?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- MFolks
Re: Electronic Tach
14 Mar 2012 15:34
Find "Loudhvx" and ask him. I believe recently he made up or found a diagram for using a car tach on a bike.
- badrhino
Re: Electronic Tach
14 Mar 2012 17:55
MFolks you are always quick with an answer. thanks
Franken Z!
Franken Z!
- MFolks
Re: Electronic Tach
14 Mar 2012 18:40
I'm at this site and at least three other Kawasaki related sites several times a day, so if I miss the initial post, I'll try to respond later in the day.
- mopguy
Re: Electronic Tach
14 Mar 2012 22:24
Keep looking in e-bay, that is where I found mine, when you least expect it, you will find one.
- mopguy
Re: Electronic Tach
14 Mar 2012 23:04
If you look at the for sale forum here you will find a 1981 KZ1000 being parted out and the whole instrument panel is selling real cheap $20.00,get a move on before she is gone.
- badrhino
Re: Electronic Tach
15 Mar 2012 01:58
Is the 81' model electronic? I thought some of them were still mechanical.
Franken Z!
Franken Z!
- nobody
Re: Electronic Tach
15 Mar 2012 02:06
ha dont tell he about that on im trying to get it :lol:
- mopguy
Re: Electronic Tach
15 Mar 2012 22:56
The 1981 came with both elctonic and cable. The one posted on here is electronic, I have the same cluster on my bike,if you need the electric tach cable I have a spare one.
- badrhino
Re: Electronic Tach
25 Mar 2012 00:33
I think I might get one from a 1983 KZ750. Hopefully it fits in the case of the old one so it looks somewhat original.
Franken Z!
Franken Z!
