77 kz650 stator
  • mjwriz
  • mjwriz's Avatar Topic Author
77 kz650 stator
30 May 2006 10:31
#50922
how do you install a stator on a 77 kz650?
  • RonKZ650
  • RonKZ650's Avatar
Re: 77 kz650 stator
30 May 2006 13:46
#50949
It should be pretty straightforward. Remove left footpeg, shift lever, starter cover first. Now take the spocket cover off. Next take off the stator cover bolts, the stator cover/stator. Unlug wiring from old stator, remove the 3 bolts that mount it to the cover and you are done. Reverse to install, using new gasket if the old one is damaged which it will be.
