speedo replacement
- Kawbeach749
speedo replacement
29 May 2006 18:59
My speedo was wobbling back and forth from 70 - 80 mph.
It wouldn't go any higher and at lower speeds it wasn't the steadiest needle either. Any idea what that was?
Anyway I ruin the speedo wotkin on it. Will a speedo from a 76 kz750 work on my 79 kz1000 ltd?
thanks for any response.
- Sandy
- Fly High,Tony
Re: speedo replacement
29 May 2006 19:52
I think they should swap over,but let Me have a look at My cross-reference program,and I'll post what I find...
Can You get Me a part number for either speedo?...
(The one on Your bike,preferably)
Post edited by: Sandy, at: 2006/05/29 22:57
1977 KZ1000 A-1
- steell
29 May 2006 22:15
25005-1031 SPEEDOMETER ASSY,MPH KZ1000-B3
25005-1067 SPEEDOMETER ASSY, MPH USA KZ1000-B4
According to www.buykawasaki.com
I guess the B3 is a 79 and the B4 is an 80?
25006-052 SPEEDOMETER,MPH KZ750-B1/B2/B3
B1-B3 = 76-78 750 twin.
- wireman
- Kawbeach749
30 May 2006 11:54
25005-1031 I found these part numbers on buy kawaski.
25005-1067
Couldn't find any numbers on my speedo. The 76' speedo in question is on ebay, and the owner dosen't know if it'll swap over either.
WIRE MAN: If you could send me a picture of your spare speedo, Ill let you know.
By the way im also having a wobble around 6 grand, and a loud nosie problem around the same rpm with my tach, Didn't have the problem before the rebuild so, maybe I did somethin wrong. Replaced tach gear drive in motor, and cable is in good shape. Any thoughts? thanks
25005-1067
- wireman
30 May 2006 21:30
ive got an extra 140mph and an extra 160 mph im thinking that yours probably came with 80mph speedo thats what 80 1000 ltds come with anyway.either of these should bolt right on.
