Running Lights
- HDDAN
Running Lights
06 Mar 2012 09:02
I just bought a 1982 KZ1000CSR. It has been a long time since I have owned a Kawi. I do not remember if the front turn signals act as running lights in this year of motorcycle. Everything else on the machine works so I am thinking that the turn signals do not function as marker lioghts. Can someone answer my question please?
- Motor Head
Re: Running Lights
06 Mar 2012 10:43
Grab the service manual for download from my signature, it will have the wiring diagram. Or here on the upper right corner of the KZR tool bar, go to "File Base" and get the diagram there. I believe you should have a dual filament bulb in each front stalk. 1 for the turn and one the running.
- MFolks
Re: Running Lights
06 Mar 2012 17:15
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
I'd open up the headlight housing, and check the connections, also the left handlebar switch pod. The older Kawasaki's have had reports of crumbled solder conections. If they look good, check the silver flasher relay cans as one is used for the 4 way flashers, and the other for turn signals. Auto parts stores carry these.
HEADLIGHT
- bountyhunter
Re: Running Lights
06 Mar 2012 17:33
On mine, the front turn signals are running lights on the lower power filament.
- TeK9iNe
- What did you do!?!
Re: Running Lights
06 Mar 2012 17:46
Yep, they are runnin lights.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- HDDAN
Re: Running Lights
07 Mar 2012 08:13
I want to thank everyone that responded to my question. I am going to repair the lights after work.
- HDDAN
Re: Running Lights
08 Mar 2012 07:54
Thanks to Motorhead's wiring diagram,I have found the ptoblem. with any 30 year old bike, you must expect that "Hackers" have worked on it. Someone snipped the two blue wires that power the running lights and substituted rear one filiment turn signals for the front two filiment turn signals.The fix, if I need them to pass inspection, will be to go aftermarket.
- Motor Head
Re: Running Lights
08 Mar 2012 10:53
Feebay or one of the members here, KZ10006 maybe, would have a set of signals for your bike. Probably cheaper and possibly better than a Chinese set.
- HDDAN
Re: Running Lights
09 Mar 2012 08:12
I found a set on fleabay from a KZ440 for $22.00. They are on their way. Thanks.
