Are these supposed to be different??
- Rockabillybobber
24 Feb 2012 00:00
Just noticed that the connections for the wires on my coils are different. The connections on one are screw on and the other looks like just push on. They are also very different in shape and I would think they would be more similar? Thanks for the help again fellow kz'rs!!
- MFolks
Re: Are these supposed to be different??
24 Feb 2012 00:24
It looks like the previous owner(s) used different coils. The top one has molded in sparkplug wires, while the bottom one's sparkplug wires are replacable by unscrewing the ridged caps on the coils. Also the top coils's primary side wiring has a harness, and the bottom one has the standard 1/4" push on termination.
You've got a mixture from different bike parts, hard to say what came stock with the bike....
- Rockabillybobber
24 Feb 2012 21:15
Anyone know why the previous owner might have used two different coils?
- testarossa
25 Feb 2012 00:01Rockabillybobber wrote: Anyone know why the previous owner might have used two different coils?
He probably just replaced a bad coil at some point in time.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Rockabillybobber
25 Feb 2012 02:00
makes sense, does it matter if they are different tho? Just curious because I noticed someone wired in some inline fuses(under the seat) that were not stock, and im trying to figure out why. I had one blow on me while riding and it killed all the power on the bike. Im doing a total over haul on the electrical system to make it batteryless and bare bones. Just tryin to get everything in order before I have any issues! haha Heres too hoping anyways
- testarossa
25 Feb 2012 04:43 - 26 Feb 2012 01:04
It shouldn't matter that they are different in appearance if they both pass all of the tests in the service manual.
The fuses were likely added because the original fuse box is a known weak point on these bikes. After time the terminals don't make good contact with the fuses and so some heat is generated. This just melts the box and it keeps going south from there.
If you haven't already, you should get in contact with the member who goes by loudhvx. He has the wiring diagrams that you need. I think that you have to add a capacitor to take the place of the battery. Lou should know for sure.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 26 Feb 2012 01:04 by testarossa.
- Powerstroke_fan
25 Feb 2012 13:53
why would you want to make the bike batteryless?? wouldnt that be hard on the charging system?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Rockabillybobber
25 Feb 2012 22:14
Ok once i get my voltmeter Im gunna check an see if they are good for my bike.
Yeah Lou is the man he's been helpin me get a wiring diagram in place!
And Powerstroke_fan I believe that if you replace the battery with a capacitor the charging system will be fine. Im also getting rid of alot of the things that would be taxing the charging system(guages,idiot lights and such)
