Cluster Fack!
  • badrhino
  • badrhino's Avatar Topic Author
Cluster Fack!
22 Feb 2012 20:24
#505705
Can anyone tell me what some of these wire are for and where they go. This bike is an 1980 KZ1000 but it has a J motor so I'm sure some of the wiring had to be rigged to work.
I have attached 3 pictures and one has marks and numbers of wires I'm having problems with.
They are coming from the coil area and it looks like the ones connected are (pos) and the others (1 & 2) look to be ground wires. I have no clue what (3) would be. :blink:
Any help is greatly appreciated. :woohoo:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • badrhino
Re: Cluster Fack!
22 Feb 2012 20:26 - 22 Feb 2012 20:27
#505707
I have no clue what purpose the big cluster (picture 2)of wires is for as most aren't connected.
Franken Z!
Last edit: 22 Feb 2012 20:27 by badrhino.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Cluster Fack!
22 Feb 2012 20:56 - 22 Feb 2012 20:57
#505712
Pretty sure those are the wires to the ignition. There should be black, green and pink if my clymer is right.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 22 Feb 2012 20:57 by andy9802gt.
  • andy9802gt
Re: Cluster Fack!
22 Feb 2012 21:02
#505715
The green and black should be the trigger wires from the ignition and I think the pinks go to the start/stop switch. The wad of shit on the backbone looks like somebody tried to fix a faulty ground or something.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • badrhino
Re: Cluster Fack!
22 Feb 2012 23:59
#505803
Ok Thanks, I'll figure it out sometime I guess.
Franken Z!
  • badrhino
Re: Cluster Fack!
06 Mar 2012 02:56
#508067
With key on I got voltage out of #1 & #2 wires. Is this normal? They are coming from the coils. The center wire #3 has no voltage.
Franken Z!
