solder joint in oil
  • azchili
  • azchili's Avatar Topic Author
solder joint in oil
27 May 2006 14:41
#50483
i'm in the process of rewing my stator because of a broken wire inside the housing.i saw a post were the wires were completely replaced and i cant find it.question?how does the solder joints hold up to oil especially if there drownd in it all the time.has anyone done this and can any wire be used(i want to make a new harness)
  • btchalice
  • btchalice's Avatar
Re: solder joint in oil
27 May 2006 15:41
#50487
it shouldnt be a problem if it doesnt touch the cases. if your worried about it you could coat it with liquid electrical tape from wally world
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
27 May 2006 15:46
#50489
Solder is unaffected by oil.
