Oil in Alternator Case
  • Brown_Muscle
  • Brown_Muscle's Avatar Topic Author
15 Feb 2012 22:34
#504273
Hey all, i just removed my stator/alternator case in order to polish it up...and found oil within. I assume the seal behind the alternator rotor/going into the engine is leaking...
I looked through my service manual to see how easy this may be to replace...and well, It appears i may need two special service tools. My question is has anyone done this at home without the SST's? Or should i just let it leak. Could it ruin the alternator by having oil on it?
-Phil
1979 KZ1000ST
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Oil in Alternator Case
15 Feb 2012 22:37
#504275
its supposed to be there.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Brown_Muscle
15 Feb 2012 22:48
#504280
Well that's a relief... i cleaned some of it out, should i just add some standard 10w-40 oil when i reassemble it? Or is it a special type of oil. Thanks!
1979 KZ1000ST
  • MFolks
  • MFolks's Avatar
15 Feb 2012 22:58
#504285
That's normal engine oil, there's no seal on the Kz1000/1100 engines as it's lubrication & coolant for the over running starter clutch.
  • beewerks
  • beewerks's Avatar
15 Feb 2012 23:25
#504290
Sorry to hijack, and if this question is redundant, but I have the same problem on my '81 KZ750. There is a little breather hole on the bottom of the stator housing and oil is leaking out of that. Is that still normal?
'81 KZ750 E2 project bike
'05 Yamaha TW200 commuter gas sipper
'08 Yamaha Zuma 50cc scoot
  • MFolks
  • MFolks's Avatar
16 Feb 2012 00:02
#504304
The 650's and 750's have different lower end bearings, I believe they are not the roller bearing type used in the Kz1000/1100 engines.
  • beewerks
  • beewerks's Avatar
16 Feb 2012 10:31
#504385
Hmm, so it sounds like I may have a problem with a stator leak on a 750. :unsure: I guess I'll have to check into it.
