Making a Kz400 special an electric start
  • oliver24
  • oliver24's Avatar Topic Author
11 Feb 2012 21:30
#503390
I was wondering if i could make my 1977 Kz400 Special into an electric start and if so what parts would i have to buy? and could you go into a little detail about how to generally do it? Thanks for the info guys
  • loudhvx
  • loudhvx's Avatar
Re: Making a Kz400 special an electric start
12 Feb 2012 02:01 - 12 Feb 2012 02:05
#503430
You might get better responses in the KZ twins forum.
www.armbell.com/kz400/index.php?sid=4bb4...094212b&mforum=kz400
Generally, you'll need right hand control for the start button. A starter relay. A starter with sprocket. Wiring. Starter clutch with sprocket and chain. And you will have to make sure you have the full-size battery, same as the KZ400D models.
The starter clutch will be installed under the alternator, so you have to have a tool to pull off the alternator rotor.
Click this to get starter parts list for KZ400D parts.
Last edit: 12 Feb 2012 02:05 by loudhvx.
