wiring simple starter/ign switch
- locolobo
10 Feb 2012 19:00
can i use a on/off toggle switch and a starter button?and if so, how would i go about wiring it up? and where on the engine do you mount the neg cable coming off the battery?thanks guys....or where can i get a ignition/starter/kill switch? if i want to go that route....
83 kz750 ltd k1 belt drive single coil
thanks guys...
thanks guys...
locolobo
- MFolks
Re: wiring simple starter/ign switch
10 Feb 2012 20:17
The Negative(-) battery cable usually goes to an engine mounting bolt. As to wiring in a toggle switch and push button start switch, get some that are rated for marine use(boating) as they must meet standards listed by the Coast Guard.
Here's some information:
www.gadgetjq.com/accessory_switches.htm
www.waytekwire.com
www.delcity.net
www.waytekwire.com
www.delcity.net
The following user(s) said Thank You: locolobo
