Replacement Coil
  • carsonr
  • carsonr's Avatar Topic Author
Replacement Coil
07 Feb 2012 19:46
#502650
ok me again now i have a question about coils . i need a replacment coil for my 82 kz440 and i was just wondering is there a after market coil ,or should i look for a used stock coil.My old coil works sometimes but more often then not its only on one cylinder. any help is appreciated
  • MFolks
  • MFolks's Avatar
Re: Replacement Coil
07 Feb 2012 19:55
#502654
How's the compression? checked the valve clearances? The sparkplug cap contains a resistor that can fail. The cap unscrews from the sparkplug wire and it can be checked with a multimeter. It should have at least 5000 ohms resistamce.
www.z1enterprises.com sell a good replacement coil.
  • bountyhunter
  • bountyhunter's Avatar
08 Feb 2012 02:30
#502743
carsonr wrote: ok me again now i have a question about coils . i need a replacment coil for my 82 kz440 and i was just wondering is there a after market coil ,or should i look for a used stock coil.My old coil works sometimes but more often then not its only on one cylinder. any help is appreciated
Get the EMGO four Ohm OEM coil from Z1 Enterprises for $36. I'm running it on my 750 twin. Works better than original.
  • bountyhunter
08 Feb 2012 02:31 - 08 Feb 2012 02:33
#502746
oops.... probably not the coil. A twin can't fire on only one side because the spark plugs are wired in series on the coil output. If either side has an open, it kills spark for both.
Last edit: 08 Feb 2012 02:33 by bountyhunter.
