What is this wire to?
28 Jan 2012 15:50 #500475 by ramtough_63
What is this wire to? was created by ramtough_63
with my counter sprocket cover off I notice this wire hanging
and for the life of me dont know where it goes
I looked through the book but couldnt seem to locate it
Attachment 100_2451.JPG not found
Attachment 100_2452.JPG not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
28 Jan 2012 15:57 #500478 by loudhvx
Replied by loudhvx on topic What is this wire to?
Oil pressure or neutral switch. You'll have to clean it a little to determine the color.
Blue/red or green/orange. But it's probably tarnished brown/yellow from oil and heat.
28 Jan 2012 16:35 - 28 Jan 2012 16:37 #500485 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic What is this wire to?
Oil pressure switch should be up behind the cylinders. Only thing I can think of is the neutral switch. Do you get a neutral light? Have you tried grounding it to see if a light comes on? Neutral switch is Lt Blue/Red. Go to Filebase up in the right hand corner of this page and find your year and model and click on the wiring diagram.
If it turns out be a brown wire then it is most likely a ground wire for something, I don't know what though.
Last edit: 28 Jan 2012 16:37 by DiamondSkyBlue1000.
28 Jan 2012 19:04 #500504 by loudhvx
If the oil pressure switch is behind the cylinders, then it only leaves neutral, as Diamond said.
According to the diagram in the filebase, neutral is light green/orange, at least that's what the colors appear to be in the PDF, (which is pretty clear).
Brown is usually switched positive. I can't imagine any reason for a switched positive down there. Usually I find most of the wires down there have a brown grimey look to them.
28 Jan 2012 19:35 #500513 by ramtough_63
Replied by ramtough_63 on topic What is this wire to?
it is a (switched) hot wire I dont remember unhooking anything when I took the cover off other than the clutch cable i have to belive its the nuetral switch anyone have a pic of the nuetral switch on a kz1000
i dont know where it is located
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
28 Jan 2012 20:11 - 28 Jan 2012 20:15 #500521 by loudhvx
If it's the neutral wire, then it isn't switched hot.
The neutral wire will appear to behave like a switched hot wire, but it is actually the ground side of the light bulb. Since the ground is lifted, it will appear like a hot wire, but will not provide current like a normal hot wire.
Now that I look closer at the diagram, the neutral wire looks like it may actually be light green with red stripe, instead of orange stripe.
If the wire is truly a switched hot wire, I can't imagine what it would be for.
Here is the wiring diagram, by the way.
www.kzrider.com/filebase/cat_view/97-197...wasaki-kz-1000-a2a2a
Last edit: 28 Jan 2012 20:15 by loudhvx.
28 Jan 2012 20:14 #500522 by ramtough_63
loudhvx wrote: If it's the neutral wire, then it isn't switched hot.
That makes sense I am pretty sure it is the nuetral wire
My next question is where does it go lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
28 Jan 2012 20:17 #500524 by etbike3135
Replied by etbike3135 on topic What is this wire to?
Where that big green bolt is! Somebody took your switch out and replaced it with a bolt.
1973 Kawasaki Z1
18 years in dragbikes
28 Jan 2012 20:19 #500525 by loudhvx
I hate those thieving neutral-switch thieves! :angry:
28 Jan 2012 20:31 #500529 by ramtough_63
Nothing worse than a nuetral switch thief!
Thats some funny shiz my nuetral lite always had a mind of its own now I know why!
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
28 Jan 2012 20:35 #500531 by gengomerpyle
Replied by gengomerpyle on topic What is this wire to?
etbike3135 wrote: Where that big green bolt is! Somebody took your switch out and replaced it with a bolt.
what he said ^^^^^^^^^^^^^^^^^^^^
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
28 Jan 2012 20:46 #500536 by ramtough_63
ordering one now thanks guys
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
