Kz 1000 battery problems ,,
- Dante
24 Jan 2012 22:05
:woohoo: my bike stars perfect ,, but after a few turns i try to started again ,, and it looks like the battery is gone ,, i tray to conecte to another one ,, and same sht happend ,, i dont know wht to do ,, .. maby the battery is not getting the chrge back ,, pls let me know,
- bountyhunter
Re: Kz 1000 battery problems ,,
24 Jan 2012 22:52
Rev the engine and measure the battery voltage: if the charging system is working, it will read 14V. If it reads 12V, it's NOT charging.
- MFolks
25 Jan 2012 00:47
If the charging system is working, at 4000 rpm you should see with a multimeter at the battery terminals, 14.5 Volts, Direct Current.
