Can I use a mini toggle switch?
- Topper
13 Jan 2012 21:20
So I've been wanting to add some heated grips to my '79 KZ750. The grips came with a giant toggle switch. I'm thinking about using a mini instead as it might be easier to find space for something smaller.
The local electronics shack has a SPDT mini center off toggle that looks like it would do the job.
The big switch that came with the grips says it's rated for 15A @ 12VDC or 10A @ 24VDC. And the mini says 10A @ 125VAC or 6A @ 250VAC. I don't know how to compare those specs.
Will this mini switch do the job or am I gonna melt it?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- bountyhunter
Re: Can I use a mini toggle switch?
13 Jan 2012 21:31
The small switch has a lower current rating. Might not handle the heater.
- MFolks
13 Jan 2012 21:52
Also the switches available from most electronc stores are not moisture resistant. Read this:
www.gadgetjq.com/accessory_switches.htm
- ramtough_63
13 Jan 2012 22:33Topper wrote: So I've been wanting to add some heated grips to my '79 KZ750. The grips came with a giant toggle switch. I'm thinking about using a mini instead as it might be easier to find space for something smaller.
not sure what brand you have but if i read this correctly the switch will be fine
A pair of Hot GripsĀ® heated grips will use between 2.5 and 3 amps (at 12.0 volts). Another way to state that same specification is that our heated grips will use between 30 and 36 watts per pair (at 12.0 volts).
in general terms 115V ac switch will compare in a 14vDC swtich in amperage load ie: 125VAC 10amp would equal 14VDC 10 AMP
UL listing is the reason why they are rated in AC vs DC
I took dc fundamentals in electronics but didn't retain much found that info on the net
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- jonnybravo
- Banned
13 Jan 2012 22:33
yes u can got some on my other bike, cool housing as well
www.cyrilhuzeblog.com/2009/04/19/mini-switch-for-1-handlebar/
- Topper
14 Jan 2012 00:18ramtough_63 wrote: not sure what brand you have but if i read this correctly the switch will be fine
These are a lot like the Hot Grips warmers and they pull about 3 amps as well.
1979 KZ750 Twin
1979 KZ750 Twin
- Topper
14 Jan 2012 00:23jonnybravo wrote: yes u can got some on my other bike, cool housing as well
I've seen a few of those on ebay. They'd solve the problem of where to mount the switch as well. If they make one with a three-way center off switch it might be the ticket. Or can you mount your own switch in there?
1979 KZ750 Twin
1979 KZ750 Twin
- jonnybravo
- Banned
14 Jan 2012 01:21 - 14 Jan 2012 01:26
yes u can, i got mine from a different company but its the same deal I put in my own switches,,, I'll try to look it up and let u know
Last edit: 14 Jan 2012 01:26 by jonnybravo.
- jonnybravo
- Banned
14 Jan 2012 01:25
here's another company, i actually found these guys after i had already ordered mine, they have a better selection
www.posh-factory.com/product.htm
- jonnybravo
- Banned
14 Jan 2012 02:06 - 14 Jan 2012 02:06
the company that made mine is closed but not to worry the above link is the same product,
AND
I found this thread on another site, should give u all the info u need
www.chopcult.com/forum/showthread.php?s=...45887b00277b5&t=1392
AND
Last edit: 14 Jan 2012 02:06 by jonnybravo.
