Gauge Cluster
  • tbaumga2
  • tbaumga2's Avatar Topic Author
Gauge Cluster
12 Jan 2012 18:39
#497792
So I've got a 81 gpz with an 84 engine in it. The tach was switched out in order to accommodate the digital one that the engine requires, but they made a mess out of the housing trying to get it to fit correctly. Also, they drilled the dash to put the extra lights in (which looks awful).
I'm wondering if I can swap out the whole cluster and put in a set from 84 and have it fit reasonably well on the 81 body. I know the styling between the years in a bit different, and I might not have enough space behind the fairing.
Anyone have experience with this? Or know off hand if it would fit? I can't measure at the moment since the bike is in storage across town.
  • tbaumga2
Re: Gauge Cluster
14 Jan 2012 12:40
#498046
better yet! does anyone here have an '84? If so, are both the gauges digital, or is the speedo still cable-connected?
  • steell
  • steell's Avatar
Re: Gauge Cluster
14 Jan 2012 12:48
#498050
Speedo is still mechanical in 84.
Re: Gauge Cluster
14 Jan 2012 14:52
#498065
tbaumga2 wrote: better yet! does anyone here have an '84? If so, are both the gauges digital, or is the speedo still cable-connected?
May determine this at kawasaki.com by looking at what cables are fitted for the speedo and/or tach.
Here's a link for help with navigating the kawasaki.com site to find parts diagrams, part names, part numbers, models sharing same part, vailability, etc.
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • tbaumga2
Re: Gauge Cluster
14 Jan 2012 23:08
#498113
awesome info, thanks!
