Bike cutting out and blowing a fuse?? Here's why.
- PRM068
10 Jan 2012 05:17
G'day guys.
thought I'd throw this out there.....maybe it's happened to heaps but it was my first time.
I had trouble starting my 82 KZ1000 today. Normally I have to get the key in just the right place but today was different. Today I'd be riding and the bike would just stop. I'd jiggle the switch, get it going, and then she'd stop again. Finally it got to the point where she just wouldn't start, and blew the 30 amp fuse.
Luckily I had a spare, threw it in, got started, and before long blew it as well.
Long story short, I got it home after a few fuses, and thought what could be wrong and where to start. It was then I noticed how loose the "Start" button was. I pulled the entire switch completely apart and started cleaning the connections. It was then that I noticed the small spring that - when the start button is pressed - pushes the button back out. The spring had completely "compressed", meaning that the start button was pretty much just bouncing about. I fixed the spring up, and cleaned all the contacts - brilliant. Starts fantastic. I can only assume that when the bike was started and running, the thing making it stop was the "Start" button bouncing around and touching it's ignition contact thereby shorting out the fuse.
Over the last couple of weeks I've found that almost every electrical contact needs some cleaning, and I'm gradually working my way through.
Peter
Peter
1982 KZ1000 LTD
- KZJOE900
- Administrator
Super Users
Re: Bike cutting out and blowing a fuse?? Here's why.
10 Jan 2012 11:11
My problem was the opposite. Bike would not start with the button. Took the control apart and found something equivalent to a rat's nest behind the button. Pain to get the spring and button back installed in the control, but did so and worked great ever since.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Mcdroid
- Gone Kwackers
10 Jan 2012 11:21
Nice post, Peter.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TeK9iNe
- What did you do!?!
10 Jan 2012 15:03
When electrical contacts get soo far worn, or nearly seperated by corrosion/poor maintenece/malfunction... they induce alot more resistance to the electrical current - thus producing alot of heat and introducing a demand for greater current from the power source.
Connetion gets very hot, so does fuse - POP!
Clean and/or solder all the contacts on the motorcycle till they are prestine, snug, and weather proof.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
10 Jan 2012 15:05
That's why I've posted this once in a while:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
- loudhvx
10 Jan 2012 15:24 - 10 Jan 2012 15:25
I once made a starter button to replace one that broke. It took hours, but, of course, it turns out Z1 enterprises sells the button and spring here:
www.z1enterprises.com/Horn--Starter-Butt...Z650-H2-H1-3937.aspx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 10 Jan 2012 15:25 by loudhvx.
- bluej58
10 Jan 2012 21:49
Ive been trying to find some of that Deoxit D-series.
I tried Radio shack , all they had was a twin pack with the D- series and gold series in these dinky little cans that cost around 20 bucks :pinch:
I don't need the gold right ?
I guess I'll try some electrical stores closer the Chicago.
JD
JD
78 KZ1000 A2A
- bluej58
11 Jan 2012 23:01
Found it at Frys for around 17 bucks :whistle:
78 KZ1000 A2A
- MFolks
11 Jan 2012 23:16
It's pricey, but a little goes a long ways.
- bluej58
12 Jan 2012 00:19
That's good because I'm doing everything.
78 KZ1000 A2A
