hazard lights on my 1000?
- andler2008
05 Jan 2012 23:05
i took my tank off and carbs off, cleaned them both. put it all back together with a new set of bars and throttle. well i turned on my right turn signal and both blinkers came on at the same time, turned on the left one with the same result. i didnt mess with the electronics and before i parked it it wasnt doing the nonsense. i neeeds help.
1980 KZ 1075
Mods? Pshh I have no idea right now
1981 Kz1000 CSR - Sold
- ramtough_63
Re: hazard lights on my 1000?
05 Jan 2012 23:14
Always start with what you did last I would say pull your left switch assy back off and inspect see if it still does it off the bike. if not make sure nothing isg rounding against the new bars.
just a suggestion
just a suggestion
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- andler2008
06 Jan 2012 03:45
Other switch assembly was off the bars when it happened. Could that have affected it?
1980 KZ 1075
- adrenalinrider
06 Jan 2012 11:04
could be a flasher? maybe? i think like 3 or 4 dollars at napa
1st Bike 1981 Kz550A Pods,Mac 4 into 1, Stage 3 Dynojet kit
- loudhvx
06 Jan 2012 14:19 - 06 Jan 2012 14:21
That symptom can happen if the hazard switch is pressed in, but the hazards are not working. Then when you use the turn signals, both sides will blink.
It can also happen if the wires inside the hazard switch are touching each other. Maybe some wires got shorted when you put on the new bars.
Sometimes a wire can get pinched when the tank is put on, or pulled off, so you may want to inspect under there too, if you can't find anything else.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 06 Jan 2012 14:21 by loudhvx.
- andler2008
06 Jan 2012 22:10
uhhhh i didnt know there were actual hazards on this bike. i was just being a smartass because i seriously didnt think they came with hazards i just figured it was a short in the control that happens occasionally.
1980 KZ 1075
- andler2008
06 Jan 2012 22:13
bahahahahahahaaha OH MY GOOOOODDDD!!!!! i'm an idiot. so funny. thanks guys. you just helped me figure out the the controls on my handlebar.
1980 KZ 1075
- loudhvx
06 Jan 2012 22:16
Here's a link to the wiring diagram.
kzrider.com/filebase/cat_view/100-1981/167-kawasaki-kz-1000-m1
I had to figure out what KZ1000 is a CSR. It's an M1. It shows it has a hazard circuit and a turn signal circuit.
1981 KZ550 D1 gpz.
Other links.
Other links.
- andler2008
06 Jan 2012 22:39
yeah as soon as you said that there's a hazard switch i went out to the bike flipped some switches and voila!!!i figured out how to use my hazards.
1980 KZ 1075
