trying to replacing turn signals. problems
  • MFolks
  • MFolks's Avatar
Re: trying to replacing turn signals. problems
04 Jan 2012 23:05
#496390
Most auto parts stores carry the older silver flasher relay cans plus the newer electronic ones.
  • newowner79kz750b1
  • newowner79kz750b1's Avatar Topic Author
  • 79 kz750b4
04 Jan 2012 23:19
#496394
Ok thank u. Any idea why I'd only have two wires for my front signals?
  • MFolks
  • MFolks's Avatar
04 Jan 2012 23:56
#496403
Probably non stock turn signals in the front,most were dual filament with running lights when new from the factory. Look inside the headlight housing for cut/disconnected wiring.
  • BikeDude2002
  • BikeDude2002's Avatar
  • Today is a good day to ride...
05 Jan 2012 00:13
#496407
Newer bulbs and / or LED bulbs can be low current draw, which does not allow the old thermal style flashers to function properly or at all. Flashers designed to specifically remedy this situation are available at www.cwswiring.com
78 KZ650 SR
90 Yamaha Radian
  • newowner79kz750b1
  • 79 kz750b4
05 Jan 2012 00:15
#496408
Ok will do. I know the signals themselves are stock. Idk if the wiring was modified for some reason though. Ill check into it. Thank u
  • newowner79kz750b1
  • 79 kz750b4
11 Jan 2012 16:59
#497573
so i got all four lights wired up and they all came on! including my headlight. bought an electronic flasher and installed that. go to use my turn signal and all four turn signals flash. including my brake light :-( what now?
