trying to replacing turn signals. problems
  • newowner79kz750b1
  • Topic Author
  • 79 kz750b4
03 Jan 2012 20:42 #496149 by newowner79kz750b1
trying to replacing turn signals. problems was created by newowner79kz750b1
so i have a 79 kz750 and im trying to replace the my front and rear turn signals with these
www.dimecitycycles.com/vintage-cafe-race...linkers-25-8302.html
so i hooked up them the way the old ones were. hooked everything up went to turn the key on and this is what happend
the font headlight wont turn on.
the high beam indicator stays on.
the front turn signals turn on but wont blink when trying to use them.
in the back the lights dont turn on at all.
i can hear the relay or whatever it is click when trying to use the turn signals but nothing happen. im not very good with wiring but i now everything is hooked up the way it was before because ive triple checked everything. any help would be greatly appreciated!
03 Jan 2012 21:43 #496158 by jonnybravo
Replied by jonnybravo on topic trying to replacing turn signals. problems
you've inadvertently moved a wire in that part of the harness that is causing a connection problem, try wiggling it again to see if it will right itself, THEN get a tester and a wiring diagram and go to work finding which wire it is, could be a loose ground
03 Jan 2012 22:03 #496160 by ramtough_63
Replied by ramtough_63 on topic trying to replacing turn signals. problems
jonnybravo wrote: you've inadvertently moved a wire in that part of the harness that is causing a connection problem, try wiggling it again to see if it will right itself, THEN get a tester and a wiring diagram and go to work finding which wire it is, could be a loose ground
+1 i swear everytime I open my headlight bucket I have 20 minutes of finding a different wire that decided it was its turn to come unconnected
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
04 Jan 2012 00:01 #496203 by Boostable
Replied by Boostable on topic trying to replacing turn signals. problems
My money is on ground... or a grounded out blinker itself. If your relay is clicking then you are getting 12v to the input side, and I would suspect that its passing it on to the blinkers themselves. Do you have a voltmeter?
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
04 Jan 2012 00:07 #496207 by 650ed
Replied by 650ed on topic trying to replacing turn signals. problems
The new lights are single filament, the original front lights are dual filament. Maybe that's the source of the problem. Ed
04 Jan 2012 00:17 #496208 by MFolks
Replied by MFolks on topic trying to replacing turn signals. problems
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
BLACK with YELLOW stripe, the ground circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
04 Jan 2012 04:05 #496227 by bountyhunter
Replied by bountyhunter on topic trying to replacing turn signals. problems
650ed wrote: The new lights are single filament, the original front lights are dual filament. Maybe that's the source of the problem. Ed
Yeah, and they are tiny bulbs that may not draw enough current to make the stock flasher blink,
04 Jan 2012 07:11 #496237 by faffi
Replied by faffi on topic trying to replacing turn signals. problems
The headlight issue is separate and is probably caused by a disconnected wire. I also think that these old Kawas had an automatic switch relay that would put on high beam if the low beam filament blew.
The dual/single filament should not be an issue - unless you've hooked your new indicators to where the running light should be plugged in? But then they should both light constantly with the turnsignals turned off.
My guess is that the rears are probably lacking ground and that the fronts are hooked up correctly. With only one indicator drawing current, the flasher relay will be confused. Try an extra wire between a known good ground and the flasher housing and see if things now work properly. If yes, you need to fix a permanent ground to each of the rear indicators.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • newowner79kz750b1
  • Topic Author
  • 79 kz750b4
04 Jan 2012 14:24 #496284 by newowner79kz750b1
Replied by newowner79kz750b1 on topic trying to replacing turn signals. problems
couple more questions.
my front turn signals were single fitment. they only had two wires. not 3. same with the rear but the rears looks like some one must have rewired the turn signals. but worked before i took things apart. lol
also another question. i havent had the bike for to long so i cant remember.
but when i turn the bike on do the front signals come on also as running lights or do they only come on when turning?
also on my front turn signals if i can remember right there is a gray wire (same as the rear) and a black and white wire
04 Jan 2012 14:51 - 04 Jan 2012 14:53 #496289 by Patton
Replied by Patton on topic trying to replacing turn signals. problems
newowner79kz750b1 wrote: couple more questions.
Per wiring diagram in FILEBASE, stock bike had blinker-only single filament rear signal lights (grey wire) and combo blinker/running front dual filament signal lights (grey wire to blinker, and blue wire to running).
www.kzrider.com/filebase/doc_download/284-z750b4
Attachment filebasekzr.jpg not found
Good Fortune! :)
Last edit: 04 Jan 2012 14:53 by Patton.
04 Jan 2012 14:57 #496291 by Patton
Black/yellow is stock ground wire color on front and on rear signal lights.
  • newowner79kz750b1
  • Topic Author
  • 79 kz750b4
04 Jan 2012 22:59 #496388 by newowner79kz750b1
I'm gunna try to mess with it next week. My bike is at a friends house since I live in an apartment complex. I know the manual says the front are dual fitment but when I took the front turn signals off and apart there were only two wires running into the light bulb. A gray wire and like a black and white I think the color was. I know it had two colors but I'm positive it didn't have 3 wires so I'm confused. Also any body know where I can get an electronic blinker relay?
