Wire overheating....can anyone advise ??
- PRM068
02 Jan 2012 02:56
G'day guys,
I've only had my 82 KZ1000 for a few weeks and still learning about bikes.
Today i was riding home from work, and noticed that suddenly my indicators weren't working - nor the hazard lights. Anyway, i got home and found that a fuse had blown. Easy fix.
The thing is, one indicator blinks normal speed, the other a fraction slower, and now the hazard lights kind of "flicker" on and off.
I read some posts on here about electrical problems and went to look at a couple of things. For starters the battery was dry. Bike starts great though, but dry. I put some water in it, but will get a new battery shortly.
The other thing I noticed (please see pics) is that a "red and white" wire seems to get VERY hot whilst the bike is running. Other wires don't get this hot. Can anyone tell me if this is normal, or at least what this wire goes to. It's the red/white wire without the plastic cover over the join.
Any advice greatly appreciated.
Peter
Peter
1982 KZ1000 LTD
- wireman
Re: Wire overheating....can anyone advise ??
02 Jan 2012 03:21
No wires shouldnt get hot,id check out the grounds and charging system to see whats going on
- PRM068
02 Jan 2012 03:49
Can you tell me what that wire is supposed to be going to ? It seems to be the only one getting hot. Is overheating generally an indication of bad earth ?
1982 KZ1000 LTD
- saxjonz
- KawboyZ
02 Jan 2012 04:30
The fuse boxes are how old? Those old glass fuses??? hahahaha better you to replace the entire fuse box with the blade type. That, I guarantee will ease your hot wires. Perhaps your ignition switch is bad too. You have to clean all those old wire ends where they connect.
Is the white (main wire) looking a little brown? Is the box melted plastic? I bet it is. I bet you that if you change out that old and modify it to work with the blade fuses your issues will go away. check all those connections and clean them well. lube them up with that dielectic grease or however it's spelled.
79 LTD B3
- PRM068
02 Jan 2012 06:59
Thanks - I'll check the fuse box in the mornign and see what it's all like. I was looking at the different fuses in the shop today and had read a little from other topics about switching over.
This red/white wire in question seems to go down to a "solenoid switch" - just under the indicator cam.
Peter
Peter
1982 KZ1000 LTD
