Total Loss Ignition for Racing
- DoubleDub
13 Dec 2011 18:59 - 13 Dec 2011 19:00
I have some info on converting to a total loss ignition for racing, but I'm wondering if someone can help me figure out how to calculate a good battery size to use in the system. This will be on a Kz650 with a Dyna-S ignition. For now I think I will be using the standard coils. No lights, sensors, starter, etc. It will be for road racing and will likely never run much more than 20-30 minutes at a time (no endurance races). Battery will be charged by external charger between races - no stator/rectifier.
Anyone know how to estimate the draw on the battery from such a system so that I can size out a battery?
Also, I'm assuming some sort of voltage regulator would still be necessary/desirable?
Last edit: 13 Dec 2011 19:00 by DoubleDub.
Re: Total Loss Ignition for Racing
13 Dec 2011 19:40 - 13 Dec 2011 19:42DoubleDub wrote: I have some info on converting to a total loss ignition for racing, but I'm wondering if someone can help me figure out how to calculate a good battery size to use in the system. This will be on a Kz650 with a Dyna-S ignition. For now I think I will be using the standard coils. No lights, sensors, starter, etc. It will be for road racing and will likely never run much more than 20-30 minutes at a time (no endurance races). Battery will be charged by external charger between races - no stator/rectifier.
Am thinking that a voltage regulator serves no useful purpose on a total loss system.
And that a good stock size fully charged battery would be okay for a thirty minute road race.
But I don't know how much smaller than stock a battery could be and continue providing full performance throughout a thirty minute road race.
Last edit: 13 Dec 2011 19:42 by Patton.
- DoubleDub
13 Dec 2011 19:42
That's what I was hoping to be able to calculate.
- DoubleDub
13 Dec 2011 21:15
So looking into this more, I may stay with points and standard coils.
I found someone on the XS650 sites saying that their coils use about 2 amps. Anyone know what the coils on the Kz's use?
Their math was similar to the following:
12v 4Ah battery, losing 2 amp drain from coils goes flat in approx 2 hours. Spark won't be made around 9v (or 75% of peak voltage) so 25% of 2 hours is about 30 minutes of usable runtime.
I'm not sure this math is accurate, or even if it is whether or not 2 amps is a good estimate for the Kz stock coils - I'm looking for input here. Also interested if anyone knows the draw of the green Dyna coils.
- DoubleDub
13 Dec 2011 21:16
Also saw Loudhvx post in another thread on total loss that he had heard of a 14v battery being used as that is what the charging system runs at. Nobody responded to that post - anybody have input on this?
- DoubleDub
13 Dec 2011 21:20
Also thinking that I need a deep cycle type battery. Aren't most lead acid batteries meant to be kept topped-up rather than being allowed to drain considerably?
- DoubleDub
13 Dec 2011 22:11
This site claims that the Dyna Green coils draw over 4 amps.
sohc4shop.com/catalog/product_info.php?products_id=44
- DoubleDub
13 Dec 2011 22:13
And this post states that they draw around 5 amps.
kzrider.com/forum/4-electrical/361165-he...t=20&start=20#367829
13 Dec 2011 22:56
Am thinking the issue about Dyna-S having a larger current draw than points, or the oem Kawasaki electronic ignition, has less to do with the minimal power needed to operate the Dyna-S, and is mostly applicable during low rpm speeds where Dyna-S consumes more power.
At racing speeds, the Dyna-S may not consume enough additional power to warrant significant consideration.
Here are some informative links on the subject:
xs650temp.proboards.com/index.cgi?board=...on=print&thread=7861
bsac10c11c12.co.uk/smf/index.php?topic=3031.0
Loudhvx's above quote is included in the thread accessed by the following link:
kzrider.com/forum/4-electrical/251955-to...loss-ignition-set-up
loudhvx wrote: The Dyna III and Dyna S are not recommended for use with the stock electronic ignition coils. They require 3 ohms or higher, according to Dyna. (Although, some have used them with 2.5 ohm coils.)
The other problem with the Dyna III or Dyna S is that they both use about 3 times as much power, (wasted as heat at lower RPMs), as the stock electronic ignition. This is not good if you are going total-loss.
If you plan on keeping the Dyna III, you'll probably want to get the charging system working well.
- DoubleDub
13 Dec 2011 23:14
Yep, that was the XS650 page that I got the math from and the forum post where I got the info from Loudhvx from. The other link was interesting. I guess I'll have to get an ammeter to find out what the ignition draws, but I won't be able to run the bike for quite a while. I was hoping someone knew what the draw of the ignition system would be.
Thanks, Patton!
Thanks, Patton!
13 Dec 2011 23:35
These links go to sites with some mathematical formulas, and some allow number plug-in with the calculations performed automatically.
As known, the difficulty lies in ascertaining the correct numbers to plug-in.
Not to mention the other variables such as battery condition, track conditions, etc.
Anyhow, here they are:
www.gizmology.net/batteries.htm
easycalculation.com/physics/classical-physics/battery-life.php
www.csgnetwork.com/batterylifecalc.html
batteryuniversity.com/learn/article/calc..._the_battery_runtime
Am also recollecting additional more specific info having been provided in other threads by loudhvx with regard to actual current draw comparisons among the different ignitions at various rpms.
- DoubleDub
14 Dec 2011 00:05
Found this post from the archives:
www.kzrider.com/archive/viewthread.php?tid=29813#pid252945
Looks like RonKz650 did the ammeter testing.
It looks to me from this info like the Dyna-S and 3-ohm coils suck about 4.2a without sparking.
As I understand things (not very well), once Ron started his bike the information for my purposes becomes somewhat meaningless as I won't have a stator supplying juice.
I'd need to run the tests myself without the charging system connected.
I think I'll have to do this just to make sure I don't run dry mid-race.
