Soon to cut and weld some frame. Do I need to...
- KZ7hundy
- 1984 KZ700
11 Dec 2011 20:14
I'm planning on cutting a chunk of the back of my frame off and welding a few things onto it as well for my cafe project. Do I need to be careful of frying any electrics? I figured I would remove the battery and not have the ignition on haha but anything else I should consider?
Last edit: 19 Feb 2013 13:12 by martin_csr.
- DoubleDub
Re: Soon to cut and weld some frame. Do I need to...
12 Dec 2011 11:06
It's a common ground bike. I would disconnect all electrics, personally, before taking a welder to it.
- zukdave
12 Dec 2011 12:15
Take the battery out just to move it from the spark's
I've welded on car's and truck's for year's and never
had an issuse with burning up the electric's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZ7hundy
- 1984 KZ700
12 Dec 2011 14:04
haha got some mixed opinions. The ground clamp helps to keep the current relatively secluded right?
- DoubleDub
12 Dec 2011 14:22
Take Dave's opinion over mine. He sounds more experienced.
- Kapahulu
12 Dec 2011 14:26
I just had a guy reinforce a seat hinge where it attaches to the frame. He used an arc welder. We removed the gas tank, battery and then covered up the wires in case of sparks. It turned out fine.
If you have a fire extinguisher it would be good to have it nearby, just in case.
2strokeworld.com
2strokeworld.com
- KZ7hundy
- 1984 KZ700
12 Dec 2011 14:30
Yeah same things I was planning to do. I am using a MIG welder though. I heard ARC was a better type, but hopefully it will go well. Thanks for the tips guys.
